Old 03-05-2004, 01:05 AM
SUTHURNREBEL SUTHURNREBEL is offline
Send a message via AIM to SUTHURNREBEL
Timing Problems
Im Replacing The Timing Belt And Head Gasket On A 1998 Dodge Carravan For A Friend Of Mine.i Have Got Everything Off Except The Timing Belt And Head. I Cant Get These Items Off Because Of The Plastic Housing That Runs Inbetween The Belt And The Block Making It To Where I Cant Take The Cams Off Without Removing The Timing Gears! Does Anyone Have Any Suggestions On Doing This The Easy Way And How Its Possible Without Taking The Motor Out? I Really Need Some Advice Because I Just Started On The Van Today And Need To Be Done Tommorrow. Which Is Friday! Thanx Alot.
new motor with timing problems gtkid39574 C/K 10 10-10-2009 09:35 PM
Timing Problem WLC Engineering/ Technical 1 07-27-2003 01:21 PM
Pajero 3.5l timing problem ratter01 Engineering/ Technical 0 09-26-2002 02:17 PM
735i -86 Ignition Timing problems jkr 7 Series 0 07-11-2002 04:56 PM
timing problem?? fubaroptik Engineering/ Technical 5 06-13-2002 03:33 PM
