Go Back   Automotive Forums Car Chat > Honda > Let's get Technical!
Let's get Technical! Discussion for hardcore in-depth motor heads!
Old 03-04-2004, 10:46 PM
88civicSiR 88civicSiR is offline
Send a message via AIM to 88civicSiR Send a message via Yahoo to 88civicSiR
will my swap smog?
I have a b16a in my 88 civic, and it's time to get my car smogged. I know they fail you at the local smog places based on the visual test, but can anyone tell me if it passes emissions at the referee, or if they know of a place i can take it to get smogged? I'm in lompoc, cali if anyone can help
Old 03-05-2004, 08:28 PM
dr_latino999 dr_latino999 is offline
Send a message via AIM to dr_latino999 Send a message via Yahoo to dr_latino999
Re: will my swap smog?
Well since I'm not a Cali person I will give you the best info I can. First make sure you all your emission control doodads (yes, my great scientific terms) are in good working order. Make sure the Cat, O2 Sensor, and everything is good. Run back the timing if possible and have the cat warm before you get there. Hopefully someone else will be able to help you out more.
Old 03-06-2004, 08:47 PM
DeleriousZ's Avatar
DeleriousZ DeleriousZ is offline
Send a message via MSN to DeleriousZ
on your way to get the car smogged, i would definitely recommend redlining the engine a few times, if you haven't done so for a while your cat may be clogged up
here's my backup...
http://www.eireann.org/diary.html#cat
"91 miles per hour in 3rd gear, and 8193 revs later, the cat began to work. As Ireland cold-turkied on carbon monoxide, the reason became clear. I'm a wuss when it comes to driving my car."
ZedEx Crew Member #6
1988 300zx turbo 5spd. 3" mandrel exhaust, filter, afco rad, e-fan, poly engine mounts, mbc at 8.5 psi, turboxs rfl-h bov, gutted plenum, etc.
blown turbo, under construction.. gt35 coming.
Old 03-08-2004, 05:21 AM
liquidflame8 liquidflame8 is offline
make sure your check engine light isn't on and you have all the carb exempt shit on your car. make sure all of your stock emissions devices are still on the motor
86 s10 smog fail, high HC. please help gunner0352 Problem Diagnosis 7 07-20-2010 04:37 PM
Great site on smog stations. callsaw Northern California 0 05-21-2010 10:35 PM
Will an engine from a 99 LX fit a 96? in_the_peg Crown Victoria 1 03-14-2009 09:06 AM
jdm swap + smog troubles batfish55 '88 - '91 Civic | CRX | Wagon | Shuttlee 2 08-05-2008 03:59 PM
will swapping out doors from a 93 cavalier RS to a 91 z24 work ObiMoeKenobi Cavalier 0 05-21-2004 07:08 PM
