Go Back   Automotive Forums Car Chat > Engineering/ Technical > Tires and Wheels
Old 03-04-2004, 10:25 PM
Project X Project X is offline
coilovers stuck..help!!
I got circuit pro coilovers on my Accord and they are cranked all the way down. The problem is that I cant raise it up. The whole sleeve turns when I try to turn the perch to raise it up. Is there any way I can get my perches unstuck so I can raise my car up. I tried WD40 didnt work. Even if I have to take it to a shop to get it done, I will. Anyone with suggestions can also email me at [email protected] I am going on an 8hr road trip so it has to come up.
Old 03-04-2004, 10:48 PM
SilverY2KCivic's Avatar
SilverY2KCivic SilverY2KCivic is offline
Cali Guy
Send a message via ICQ to SilverY2KCivic Send a message via AIM to SilverY2KCivic Send a message via Yahoo to SilverY2KCivic
Yet another reason why coilover sleeves are no good...
Silver '00 Civic EJ6 Coupe
PureHonda original member since Feb. 2000
D-series revolution For pics of my baby, click here!
All rights reserved... All BITERS served!
"The last time you had THIS much fun driving a car, it cost a quarter, and gyrated in front of the supermarket."
i have yet to see any well done imports around here. most are road toilets driven by some high school punk -Drift
hessemer69 on AIM
Old 03-05-2004, 01:28 AM
BullShifter's Avatar
Re: coilovers stuck..help!!
My best advice would be to soak & keep soaking the collars in penatrating oil for 24hrs or more. WD40 is about the worst product you could use. Use a pipe wrench to hold the collars while using the spanner wrench to adjust collar. If the threads are very rusted you may want to remove each strut assy. & clean threads with a wire brush & then soak for 24hrs or more. Once the collar is free coat the entire threaded surface with anti seize, run collar up & down, and keep on applying as needed. Depending on the climate(salt) it's a good idea to move the collars monthly or every 7500 miles with tire rotation & brake service.
Don't forget when the ride height is changed an alignment is needed.
Old 03-06-2004, 03:10 PM
Dezoris Dezoris is offline
Mod for life
Send a message via AIM to Dezoris
You guys are hilarious, threaded body shocks have just as many problems with threads stripped or too course to allow the collars or perches to move up or down.
Better yet, most coilover kits with the exceptions of the Comptech kits don't come with nylon washers to sit between the spring and perch so the spring. Most people who have the kits without notice shreading and binding on the bottoms of the springs which make it 10x harder to raise and lower.
In bad weather threaded body shocks threads corode and seize up regularly without thick coats of lithium grease.
M.Sanew - AutomotiveArticles.com
Old 05-29-2004, 12:46 AM
bmc2213 bmc2213 is offline
Send a message via AIM to bmc2213
does any one have another answer to how to get your perches unstuck and keep them from sticking?> looks like an arguement to me and not advice
Old 05-29-2004, 04:34 AM
Cali Guy
Re: Re: coilovers stuck..help!!
That's why you keep them clean and learn how to maintain them, and maybe even get some rust preventative coating to put on the sleeves once you have the desired height set on them.
I'm in CA, so I don't have to worry about weather much with my Teins. I also have a can of that "Rust Proof" stuff that they make for their coilovers to coat them with after adjusting so that rust won't manifest itself on the threading of the shock. So far I haven't had to use it, and I periodically clean the threads of any dust/dirt as well as the rest of the shock and spring units.
Raising the collars is hard, because the higher you go, the more force you are applying to the spring as it compresses. The more you compress it by raising the height of the collor, then the more difficult it will be to turn. Simple solution is to remove the entire strut unit, and adjust them OFF of the car if they won't work otherwise.
Again I'll say, this is why true coilovers are better. Unlike a sleeve, with a true full coilover, the threaded shock body is BOLTED to the frame and suspension arms, where with a coilover sleeve, it's free standing and WILL turn with enough force, and a threaded shock WILL not rotate the entire unit as you turn the perch collars to adjust height. That's what I was getting at Dezoris.
hessemer69 on AIM
Old 05-30-2004, 07:44 PM
hi thanks for the reply i have heard tein makes a setup for street and strip while maintaining good drivability is this truie? also i really like the look of your car i have the same body style in black would you be willing to tell me all that you have done?
Old 05-30-2004, 08:41 PM
96Civic_Coupe 96Civic_Coupe is offline
Banned
yea, that car is sick.
Old 05-31-2004, 12:33 AM
yeah im trying to make a nice clean car like that i dont wwant attention from the cops here. just need a fast ride with some style... and a b16b lol
Old 05-31-2004, 08:54 AM
Icantgetno Icantgetno is offline
It just kills me that both of them suggested sleeved coil overs for my ride
Old 05-31-2004, 02:52 PM
Cali Guy
Street yes, strip no. Tein don't make strip oriented kits really, just track oriented in terms of road racing, but nothing for drag. Coilovers are plain and simple a waste of money if your main style of racing will be drag.
On the street the Teins have excellent driveability. You can (with the SS and higher models) tune the shock dampening so that it feels almost as soft as the stock suspension setup, or you can tune then so that they ride damn near N1 stiffness. I got a 2kg spring upgrade on my Tein SS and they still are very streetable, even with the 559lbs./ft (10kg) front springs, and 336lbs./ft (6kg) rear springs. I just got some bright blue Megan Racing rear lower control arms last week, and the rear end feels even MORE stiffer now. Next week I'm adding a Megan Racing front H-brace to the suspension, and then not too long from now, I'll be adding some SRR spherical bearings for the steering pinion which will make my steering quicker and more responsive.
Anyways for a full rundown of what I have, click here.
hessemer69 on AIM
Old 05-31-2004, 02:56 PM
Cali Guy
I dunno if you're refering to me, but I NEVER suggest any sleeve coilovers other than Skunk2's or Ground Controls. Also keep in mind that sticking perch collars can happen on true coilovers as well. It's all dependent on where you live, and what sorts of elements your car and suspension is exposed to. If your's are sticking, then maybe once you get them loosened, put some sort of lube or grease between where the 2 collars lock together, to make them easier to get undone in the future. I'm not sure if this is advisable though, so email the manufacture of your sleeves before you go doing this.
hessemer69 on AIM
Old 05-31-2004, 09:24 PM
Im still trying to figure out a solid spring solution to my problem, I have shitty coil overs now and want to stay away from them.
Old 06-01-2004, 03:07 AM
Cali Guy
I know you've seen other threads about what springs are good, on here.
Eibach, Neuspeed, Tein S. Tech, and H&R are all the ones I'd recommend. All should be able to be had for around $200 if not less.
hessemer69 on AIM
Old 06-01-2004, 10:52 AM
hey Y2k those t
ein ss sound sweet wheres a good place to get them? also how do the match up with spoons dampers?
also can you add the edfc to any set of tein coilover shocks?
