wrong forum, for starters... del Sol is compatible with 92-95 civics. And if you're going to ask that, SEARCH... I mean seriously.. there's another thread about a B engine TWO THREADS ABOVE THIS... look around, then ask if you don't find.
For some reason I feel like being nice, and I'll answer your questions..
the b16 is the same engine in the civic Si. Find a 97 Civic Si and swap it in. If your car's autotragic, you're gonna have a hard time mounting the tranny due to different mount points for auto/manual. Save your money and just get a USDM engine. Everyone thinks JDM engines are hot because they get more horsepower or whatever... well yeah. If you put the 100+ octane gas that Japan has in a USDM engine, it would get higher hp, too. Cable tranny uses physical cables to change gears in the tranny and is a nightmare to fix if you ever need to. Hydro uses gear series and a hydraulic shifter which relies on those gears to change the transmission gears... something like that... it's 3am and too damn early, but I can still find my close button
