Go Back   Automotive Forums Car Chat > Nissan > Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35
Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35 Excellent platform and the good ol' VQ30DE and VQ35DE engines.
Old 03-04-2004, 08:12 PM
turk66460's Avatar
turk66460 turk66460 is offline
Send a message via AIM to turk66460 Send a message via Yahoo to turk66460
Panty Line
Got your attention. Can someone help me. P1335 code came up, whats Ignition malfunction, Engine misfire. What is that about and how do you reset your airbag light. Thanks.
Old 03-04-2004, 09:16 PM
bk2kmax's Avatar
bk2kmax bk2kmax is offline
Re: Panty Line
Who's attention where you aiming at? Anyway, I do not purport to be some kind of expert in these areas, I just do some research and I also base my replies on some experiences.
If I were you I'd go over to maxima.org and ask the experts for your particular gen of max, they would know more about these codes pertaining to your gen.
My guess is that your Ignition Malfunction comes from your computer failing to recognize the signal sent from the computer to the starter or starter selenoid to tell it to engage.
Engine misfire-again another guess is that your computer is not sending or sending a faulty signal to your cylinder banks and therefore not firing properly or in the orderly fashion in which they are supposed to fire. It is also possible that your spark plugs may be not be gapped properly.
As far as resetting an airbag light, I have the foggiest of ideas, I naturally assumed that this light only stays on when your airbag requires some type of servicing or has either been deployed or malfunctioned.
My total best guess from what you've told me is that your computer's brain is going bad, it is either that or your Engine Wiring Harness is going bad and causing faulty signals to be sent to your engine's computer or ECU when in all actuality there is nothing really wrong with all of these other components, rather only the Engine Wiring Harness itself.
If I were you I'd take my car to Autozone and get them to run a free diagnostic test on it and they can or will give you more codes and in most cases be able to explain what these codes mean. Also in most cases they can reset some of these things so that the codes/lights don't come on, the only problem with that is that if it is the Wiring Harness the lights and codes will be present again and soon as you shut your vehicle off and then start it back up again.
Did I mention that this test is FREE. I wish you luck and I hope I only helped and not further confused you.
By the way, it should read bk2k3Max, not bk2kmax.
Old 03-05-2004, 05:13 AM
turk66460's Avatar
Re: Panty Line
bk2kmax
Thanks alot for the info. Well there is somestuff i forgot to mention. OK I will start off. Well my car has a hard ime starting up. Usually in the cold weather. I replaced new spark plugs Bosch Platnium, New Starter, Battery, Camshaft, Crankshaft sensor, Cleaned the throtel body out, New Knock Sensor, Used MASS sensor, and new temp sensor. It still does it. Today i went to Auto because my check engine light was on. So i checked it myself, and this time i got 1 code which is Ignition malfunction or Engine misfire. So i wana know if my Coil packs are bad. Usually a code came up all the time was Crankshaft sensor but that was new. That code went away. Anyway for the airbag light i took it to the dealler and they tried to start my car so many times that when i got there my battery was dead and the airbag light was on and they couln't find the problem. Wierd huh a dealer couln't find my problem on top of that they gave me the car with a dead battery and my airbag light on. So thats the whole story.
Old 03-09-2004, 06:30 PM
bk2kmax's Avatar
Re: Re: Panty Line
bk2kmax
Turk, if the dealer couldn't find it, I'm no mechanic nor some expert but the only thing I can think of is that your Wiring Harness is bad, did you bother to have them check it out?
They will usually pull on it, or yank the hell out of it to see what codes or if the codes change while they are doing so.
If you changed all of that and your car is still acting funny then it is obviously something to do with your car's computer (brain) or your wiring harness sending the info from your car's various systems to each component or the computer telling it what to do.
These are only my best guesses and if I were you I'd take it to another Nissan dealer other than the one you went to and get it checked.
It's sorta like going to the doctor and he tells you that you have cancer, are you just going to lie down and accept the first thing that you're told? No, you'll get a second and third opinion, do the same with your car if you plan to keep it.
Good luck
Old 03-11-2004, 05:54 AM
turk66460's Avatar
Re: Panty Line
Hey people thanks alot for everything. I appericiate everyone opinion thanks again.
