Old 03-04-2004, 02:28 PM
yak103 yak103 is offline
Anyone have comments on D16A9 ?
I'm from Belgium and my block is a D16A9... DOHC non-VTEC. The car is a 1989 Civic, known HERE in Belgium as a 1.6i16v. I don't see many threads on the D16A9 so I was wondering what the equivalent is with you guys, as I'm considering the proverbial B16 swap... Thanks for your comments !
Old 03-04-2004, 09:54 PM
91civichatch2571's Avatar
91civichatch2571 91civichatch2571 is offline
Send a message via AIM to 91civichatch2571
D16A8 and D16A9 are both DOHC ZC engines. Thats what we call them anyways. A lot of people here have them (me being one). Not bad little engines.
ZC stuff
http://dh-racing.com
http://www.thezcr.com/html/zcbook.php
http://dmoore.com/crx/zc.htm
http://www.jgenginedynamics.com/HOME%20PAGE
http://www.theoldone.com/
Old 03-05-2004, 12:41 AM
BLU CIVIC's Avatar
BLU CIVIC BLU CIVIC is offline
調整器
Send a message via MSN to BLU CIVIC Send a message via Yahoo to BLU CIVIC
Re: Anyone have comments on D16A9 ?
wern't those in the like 90 tegs?
The name's Adrian
1990 Civic HB Si - 265.7whp/223tq @9.2psi. Tuned on NepTune by J.Mills
1991 Civic Sedan DX - 296.3whp/230tq @1bar. Tuned on NepTune by J.Mills
1991 Civic Sedan DX - 185.8whp/139tq. Tuned on NepTune by J.Mills
2006 G35 Coupe 6MT - Stock
2011 CR-Z - Stock
Old 03-05-2004, 04:24 AM
Civic Jim's Avatar
Civic Jim Civic Jim is offline
Send a message via AIM to Civic Jim Send a message via MSN to Civic Jim
they are great engines, its the EDM version of the "ZC" engine, its approx 133 BHP without a cat i think
I had a 1.6i-16 civic , went like hell and sounded sweet with an intake on , brilliant engines IMO, if you are looking for parts etc for your engine do a search for ZC they are almost identical engines, as in VERY close matching
Jim - Your Resident EDM Biatch
B16A1 I/H/E
4TH GEN UK SITE
Honda Civic EE9 1.6-i VT
Old 03-05-2004, 05:22 AM
I've already dropped in a KN filter and removed (most) of the resonator... I was hoping to swap a B16a or b in, but it looks like too much of a hassle/risk... I think I'll try and keep the D16A9 and have it reconditionned. Does someone know how much it costs, or if it's ill-advised ? Thanks for your help, guys. And I agree. D16A9 DOES sound sweet and DOES get the job done...
Old 03-05-2004, 05:25 AM
Civic Jim's Avatar
well mate if your going to recon the engine, you may as well do it with performance parts, and there are turbo kits available if you want to increase performance, cams, valves, turbo kits, manifold, if your guna keep the engine and recon it , i would seriously suggest changing everything with performance parts
B16A1 I/H/E
4TH GEN UK SITE
Old 03-05-2004, 09:23 AM
88_SC_CRX_Si 88_SC_CRX_Si is offline
How many miles, is it buring oil...?
Most "D" series OEM Honda engines, can go up to 200 hp rather safely, even more using a stanalone in some cases. Main thing is keeping a sharp eye out for detonation, so it does not happen....
The ZC has sorta become a tuner's engine, due to having to go to a dyno, in order to get the most hp out of them. Also, going with some adjustable cam gears, will get some more hp. However, that again calls for a trip to a dyno to get them set-up properly. "Butt" dynos are really not sensative enough, once your past a point...
As far as cams go, what kind of driving do you do...? If it's everyday stop and go traffic. Then you will want to look at cams that have good low end. Or vice versa if you do a lot highway driving. No point in getting a high rpm cam, when traffic won't let you use it....
88' CRX Si - JRSC @ 6psi Z6 Mini-Me, JDM SiR Conversion
NOS #5122, JR Liquid InterCooling System
ZYDNE SECU, 450's
B&M FP Set, B&M Command Flo
AutoMeter - Phantom FP, A/F, N2O, Boost gauges & pods,
ARP HSKit, AEM Pads, 87' HF Drums, DYI CAI
Old 05-05-2004, 09:24 AM
Mileage is 140K, she doesn't burn oil (nothing worth mentionning anyway) The whole drivetrain has 31K on it and the last dyno/tests gave 137hp at the wheels, compression 9:5 So I'm not worried... but I'm anticipating - B16A2's are so common and cheap here it'd be a shame not to try the swap
Old 05-05-2004, 09:42 AM
KoRnSaQ KoRnSaQ is offline
Send a message via Yahoo to KoRnSaQ
well, if you want to go b-series, the only extra parts(besides the engine) would be mounts, shift linkage, axles, and the hub/knuckles(or whatever they are called) plus a v-tec controller.
KoRnSaQ
Old 07-05-2004, 04:38 AM
Thanks for the info, sounds straightforward enough...
Old 07-05-2004, 07:37 AM
doug294 doug294 is offline
Send a message via AIM to doug294
137hp at the wheels? What was your torque? I would screw a B16 you are pretty close to them now.
I get paid to read e-mails when I'm bored....are you bored?
http://hits4pay.com/members/index.cgi?doug684
