Go Back   Automotive Forums Car Chat > Engineering/ Technical > Forced Induction
Forced Induction Discuss topics relating to turbochargers, superchargers, and nitrous oxide systems.
Old 03-04-2004, 12:57 PM
Shawn C Shawn C is offline
need someone who knows a lot!
Hey, I am putting in my turbo as a school project,, so i have to right a stupid paper to go along with it. If u guys would help me I would be very appretiative! I just need a long dicription of a supercharger and a turbocharger,, and somthing that many people dont know about them... I already knwo a lot I just need a quote to put into my paper.. thanx
Old 03-04-2004, 01:05 PM
juicy19 juicy19 is offline
Send a message via AIM to juicy19
Re: need someone who knows a lot!
Use the search function. There's so much info in these forums that you can use. Take about 10 minutes and you'll find what you're looking for.
2001 Honda Prelude SH
DC Header
3" Intake with K&N
GReddy Exhaust
Unorthodox Racing Pullies
JET enhanced ECU
10.3 OBX Plug Wires
Old 03-04-2004, 01:33 PM
Thanx
Old 03-04-2004, 01:41 PM
Polygon's Avatar
Polygon Polygon is offline
The Red Baron
Send a message via MSN to Polygon Send a message via Skype™ to Polygon
A good site for a good explanation is How Stuff Works.
All you need to know is there.
Old 03-04-2004, 01:45 PM
Checked the search.... and already have stuff from how stuff works, its all good stuff but i just need a quote from someone about something dealing with superchargers and turbochargers.
Old 03-04-2004, 02:24 PM
Reed Reed is offline
Send a message via AIM to Reed
you wont have a hard time finding something that most people dont know about a turbo
cause most people dont know shit about htem
Old 03-05-2004, 08:41 AM
88_SC_CRX_Si 88_SC_CRX_Si is offline
Re: Re: need someone who knows a lot!
Here is one.... Depending on the amount of boost, intake speeds can reach over the Speed of Sound. Due the amount of CFM that is getting moved through the system. Which does make sense, when you stop and think about.
88' CRX Si - JRSC @ 6psi Z6 Mini-Me, JDM SiR Conversion
NOS #5122, JR Liquid InterCooling System
ZYDNE SECU, 450's
B&M FP Set, B&M Command Flo
AutoMeter - Phantom FP, A/F, N2O, Boost gauges & pods,
ARP HSKit, AEM Pads, 87' HF Drums, DYI CAI
Old 03-05-2004, 09:33 AM
Hypsi87's Avatar
Hypsi87 Hypsi87 is offline
I got your v-8 swingin!!!
Send a message via AIM to Hypsi87
Re: Re: Re: need someone who knows a lot!
ahhh but a turbo does not increse the CFM your engine flows.... A turbo is a pressure multiplier, not a pressure adder. A turbocharger/supercharger increses air density(mass) besides air only moves in your intake when an intake vave is open. so air flow is always changing direction dependong on your firing order. no way that it reaches the speed of sound
Grand National. Going fast with class.
Voted FASTEST street car on AF.
Here is the proof!!!
1987 Buick Grand National.
Back in action!!!!
1999 Ford F-250
Tow rig from hell 598 Ft-lbs.
ASE Certified in...
Mobile AC
On Highway medium duty diesel engines.
Off highwayy medium duty diesel engines.
On highway trucks.
Working on the eletronics certification
Member of
A.A.N.B.C- Afer against non boosted crews #2
Old 03-05-2004, 10:31 AM
Re: Re: Re: Re: need someone who knows a lot!
I will "try" and find the article/website I found it on....
ZYDNE SECU, 450's
Old 03-05-2004, 10:46 AM
FDTT FDTT is offline
If you broke the spped of sound (760+mph on land) in your intake manifold the thing would explode. The pressure that would be generated would be so grate that the manifold would grenade.
The compressor blades on the other hand probably do brake the speed of sound. I mean, they revolve at over 20krpm.
The Apache attack choppers rotor blade (tips) can brake the sound barrier. Thats why they have the tear drop shape at the end of the blade. As to cause less turbulance when doing this.
Dont drive faster than your angels can fly
Old 03-08-2004, 08:35 AM
Could not find the site nor am I a math nerd, sooooo don't use that until I can find out otherwise... hehehehe
Anyway, you peeps don't think intake speeds could be hitting that fast, in a Top Fuel/Funny Car pushing 6000+ hp...
Just curious....
ZYDNE SECU, 450's
Old 03-08-2004, 11:30 AM
duplox's Avatar
duplox duplox is offline
Send a message via AIM to duplox
Well, I figured the place air would be travelling the fastest would be the turbo compressor. Compressors can hit speeds of over 50,000rpm, but a normal turbo(50,000+ requires ceramic wheels, water cooling, improved bearings, etc) can only get to about 50k. Using a smallish 3" wheel, at the very edge it is travelling at 446.25mph. not too shabby, but not close to the speed of sound (761.2mph).. Using a little more math, we can figure out that it would take a 5.11" wheel for the very edge to hit the speed of sound.. not that huge of a wheel, but still pretty big.
I know guys who spin their 351c v8s(5.7L) to 9500rpm, which means that it takes .00315 second for the engine to intake 44.5 cubic inches of air. The intake runners are around 2" in diameter. That means in .00315sec the air moves 14" in the intake. That comes to a speed of 4430.38in/sec, or 251.72mph. Fast, but nowhere near the sound barrier.
I doubt air in the intake manifold hits the speed of sound. I'm skeptical that a normal 5+" wheel could hit 50,000rpm. I'm sure there are race engines out there that do it on a regular basis, which is why they're torn down after every race! Maybe you were reading about intake runner length tuning, because that is based on pressure waves bouncing off the back of the intake valve just after it closes and heading back up the intake runner at the speed of sound, hitting the plenum and reflecting back, and if your runner length is just right your intake valve will just be opening again as the pressure wave returns. But that isn't really that applicable with forced induction engines. Thats stuff for max hp/cu in naturally aspirated or NOS cars. It isn't concievable for a N/A car to have intake speeds near the speed of sound, because that would mean your intake manifold is extremely restricitve. If they're that restrictive, the engine wont be able to get to a speed that'll make the air move at 760mph.
Old 03-08-2004, 11:35 AM
bigpun bigpun is offline
Banned
if your looking for someone who knows alot boy you found the wrong site. if you wanna know the technical definition of a blower---
now this is right out of the automotive dictionary
( something that blows air up your ass)
Old 03-09-2004, 09:19 AM
You just proved that intake speeds can reach that fast...
Thankyou for answering that Q for me....
ZYDNE SECU, 450's
Old 03-09-2004, 06:55 PM
projectsilvia97's Avatar
projectsilvia97 projectsilvia97 is offline
Send a message via AIM to projectsilvia97
what does this have to do with anything?
Question for someone who knows master cylinders!!!!!! SPL Tech Grand Cherokee | Grand Cherokee SRT8 1 08-15-2006 04:14 PM
someone who knows model kits sellers from ebay tha are cheap? pollapellos Car Modeling 3 02-22-2006 03:12 PM
i need help from someone who knows somthing hearseman666 General Discussion 8 11-20-2003 01:18 PM
i need help from someone who know somthing hearseman666 General Discussion 3 09-08-2003 11:47 PM
I need advice, from someone who knows their shit. PFCfutrell Tires and Wheels 17 11-30-2001 12:19 AM
