Go Back   Automotive Forums Car Chat > Ford > Explorer | Explorer Sport Trac
Old 03-04-2004, 11:21 AM
rdem_crew rdem_crew is offline
Angry 99 explorer trouble starting when cold
I have a 99 explorer with 67,000 miles on it and every morning( 35 degrees outside) when I turn the key it tries to start and then shuts off. The only way I can keep it started is to give it a little gas. I have changed the fuel filter and new plugs and wires. But every morning after sitting through the night it will not start. Tried fuel injection cleaner also. After it warms up it starts no problem, would appreciate any advice. Thanks
Old 03-04-2004, 12:19 PM
Opera House Opera House is offline
Re: 99 explorer trouble starting when cold
Could be IAT (intake air temp) or coolant temperature sensor bad. That would tell the enngine computer to run a leaner mixture than it should. More likely it is a sticking IAC valve that does not allow the engine to rev up on its own. IAC is located on the side of the throttle body under the plastic cover. Two wires and it removes with two screws. Spray some throttle body cleaner in it and see if that improves it. The IAC has a lot of different problems asociated with it. Does it idle real low when the engine is warm? If it is still functioning electrically, you can remove the electrical connector and the engine will idle down to a point that it almost stops. Some find it easier to replace it for about $65.
Old 03-04-2004, 12:25 PM
scdzkt scdzkt is offline
my 2000 explorer has been doing the same thing for almost a year now...I don't know the cause b/c some days it is fine and some days it won't idle... I thought it only did that when it was rainy, but then it started doing it when it was hot or cold, or sunshiny... If you figure it out PLEASE let me know b/c I am tired of having to drive with 2 feet, one on the gas (at all times) and one on the brake!!!!
Old 03-04-2004, 02:15 PM
Opera House: It idles fine once it has warmed up( 1 minute) about 700 rpms. I will try what you have suggested. if you can think of anything else please free fell to tell me. Thanks
Old 03-11-2004, 10:09 PM
JMB52004 JMB52004 is offline
Temp Sensor
I had the same problem with my 2000 about a month ago. I live in New England and thought it might just be the negitive digits but after a week i took it in to work to scan it. It turned out it was the coolent temp. sensor (for the computer). A somewhat easy and cheep fix. For like $25 a new OEM sensor from FORD. Make sure if you take the head gasket off to re seat it properly or you'll have one hell of a vacume leak.
95 Mustang 3.8L-trouble starting... DDP87 Mustang Problem Diagnosis 3 09-27-2009 08:47 AM
hard to start when cold 88alldae Caprice 2 08-03-2009 09:16 PM
trouble starting when cold O'Side Chevy Man C/K 1 10-27-2005 12:30 PM
explorer won't idle when cold tommcl Explorer | Explorer Sport Trac 1 10-22-2004 08:53 AM
