Go Back   Automotive Forums Car Chat > Nissan > Skyline | Skyline GT-R | Stagea | Laurel > Performance
Performance Discussion about performance modifications and issues.
Old 03-04-2004, 08:06 AM
Ismail Ismail is offline
Unhappy rb20dett
i want to know whats the max psi i can go with rb20dett as standerd and i want to end with 350hp with standerd too..
Old 03-04-2004, 09:42 AM
RazorGTR's Avatar
RazorGTR RazorGTR is offline
Skyline Man
Ok is it in a skyline or another car?
What ecu are you using?
any other mods such as exhaust and filters?
You don't own a Skyline, then don't cry to me about it!
1992 Silver R32 GTR tickled to 450hp. - Sold when I left NZ in 2004
Arguing on the Internet is like competing in the special olympics. Even if you win, you're still retarded.
Never confuse kindess with weakness.
AF user guidelines, Please remember to abide by them
Old 03-04-2004, 10:43 AM
Re: rb20dett
yes in a skyline, standerd ecu, with filters and im trying to find an exhaust if u can tell me which one is good for me.
thanx for reply.......
Old 03-04-2004, 07:14 PM
GTES-t's Avatar
GTES-t GTES-t is offline
As far as the engine you're saying it's an RB20DETT, is it actually a twin turbo? If so, it's not a stock RB20, which is single turbo. Or did you accidently put RB20 and mean RB26, basically, is the Skyline a GTR or GTS-t? Just trying to clarify the engine, if you have the RB20, it only comes factory with a single turbo and is the RB20DET. Now, it could be twin turbo if someone installed the GTR's exhaust manifold on it and twin turbo'd it.
Anyways, the max (recommended) PSI you can run on a standard RB20 is .9 to 1 bar which equates to ~ 13 to 14.5 psi. Now I've seen people that have boosted it up to 1.2 bar on a stock engine which is about 17.5 psi. However, it is highly recommended that you do not want to exceed 14 psi! Odds are your engine will run to lean over that and start melting pistons.
If you want anything over 14, you need to start changing parts on the engine... injectors, fuel pump and remap your ecu at a minimum! But to ensure your engine lasts longer and runs safer, add these to the list... Air Flow Sensor or add on signal convertor, fuel pressure regulator, upgraded/hybrid turbo and larger intercooler. Provided I din't miss anything, this should be able to take you up to ~18 psi safely.
I would also recommend installing a metal head gasket also, which is thicker and lowers your compression. You can get away without it up to 18psi, but definitely required if you go over that along with other internal modifications to the engine.
1990 Skyline GTE/S-t 4 Door Updated 6 Mar
Swapped out RB20E with RB20DET
Trans converted from Auto to 5-Speed...
Now with SR20DET 5-Speed
Installed Type M 5-lugs and brakes, R32 GTR rims and 2-Dr rear end (Tail lights & bumper)
1994 Isuzu AMU
US Spec Amigo with JDM Isuzu MU (Mysterious Utility, as it's called in Japan) nurf bars and hatchback style hardtop.
Old 03-04-2004, 09:03 PM
Smile Re: rb20dett
thanx for reply..
ahaaa my r32 is gts-t 1992 and its singel turbo....
im thinking to add fuel pump, injectors, exhaust, an intercooler and A/f meter.
i want to know what do u mean by remap my ecu?
thanx agine
Old 03-05-2004, 04:52 AM
GTES-t's Avatar
What an ECU remap is, when you change injectors for example.
Your stock injectors are 270cc. When your engines running, it's getting signals from the ecu when to open, for how long, etc.
Now, when you upgrade injectors, to 550cc for example, the ecu does only what it's programed to do. So it's giving the larger injector the same signal of when to open, how long, etc. This translates into to engine not running correctly, if at all.
So, what you'd have do, is take your stock ecu to a tuning shop that can retune/reprogram them. They 'remap' the new values in it so that the ecu can now send the correct signals to use the new injectors.
There are other options then remapping the ecu. In this case, you could buy an Injector controler that goes between the ecu and the injectors and changes the old signal from the ECU to the new signal the injectors need to be used properly. Also, there are aftermarket ecu add on engine management systems (such as greddy eManage) and ecu replacement options (Apexi Power FC).
I hope this helps you out. It can be confusing.
1994 Isuzu AMU
Old 03-05-2004, 10:16 PM
Talking Re: rb20dett
thank u vary much for the info that u gave me..
its realy help me out thanx agine.....
Old 03-05-2004, 11:12 PM
Re: rb20dett
by the way how much it will cost me to retune the ecu... thanx
Old 03-06-2004, 05:48 AM
GTES-t's Avatar
I'm sorry to say I don't know how much a retune costs down there. The best thing to do is find some car tuning shops and ask around.
Sorry I couldn't help with that one.
1994 Isuzu AMU
Old 03-06-2004, 08:58 AM
Thumbs up
No worries mate.....
Rb20dett or 26dett zxracer1784 240SX | Silvia | 200SX(RWD) | Gazelle | 180SX 41 02-09-2016 06:49 PM
RB20det to RB20DETT? TerminalVelocity Performance 2 06-22-2006 11:32 AM
RB20DETT Over Highflowed Single! -Joel- Performance 11 11-10-2001 11:32 PM
