Go Back   Automotive Forums Car Chat > Toyota > Tacoma
Old 03-03-2004, 09:16 PM
syke101 syke101 is offline
Is this normal?
I have a 2001 4x4 TRD excab.....when in 4 wheel drive and backing up while cutting the wheel it seems like it doesnt want to go and the back tires will start to slip a little.....hard to explain....for instance i was backing into my driveway and i was on asphault and it was like something was getting kinked up and then the rear tire would jump....is this normal?
Old 03-04-2004, 01:38 AM
redtoy92 redtoy92 is offline
Re: Is this normal?
this doesn't sound normal to me!? but i am not 100%sure what you are saying. This sounds normal when turning on pavement with a locker. sorry hope some others will reply with something for you. red
Old 03-04-2004, 07:07 AM
'03DC3.4TRD4X4 '03DC3.4TRD4X4 is offline
RELAX buddy, this is a great indication that your 4WD system is working correctly!! Low range will magnify the conditions you describe and engaging that locker would downright make you believe that you are about to snap an axle half shaft!! Your truck is good to go just keep it in 2WD on the pavement!
Old 03-04-2004, 07:24 PM
Re: Is this normal?
Thanks Bro! Glad to here that, I didnt think it was a problem but just wanted to make sure.....
Old 04-25-2004, 12:34 AM
Snobrdrblinkchik Snobrdrblinkchik is offline
Re: Is this normal?
perfectly normal...which is why it's not recommended to have 4wd engaged on any high traction surface (dry pavement)
