Go Back   Automotive Forums Car Chat > Ford > Focus | C Max
Old 03-03-2004, 08:11 PM
speedy6301 speedy6301 is offline
Wink wanna mod but dont know how
i just got a focus and i wanna start to mod the apperence
wut i wanna do is put underglow, sound system, but underglow first however i dont know how to installe it. can anyone help me?? or give me links that can teach me how to instale it thanks for the help
Old 03-04-2004, 11:36 AM
hopeless4life hopeless4life is offline
Send a message via MSN to hopeless4life
Re: wanna mod but dont know how
Its not the easiest to do. You have to secure the 2 longer tubes slightly in from the rocker panels, which usually means drilling, then if you don't have a hole to run the wire into the car, you have to drill a hole through the floor, becuz you don't want wires running all over the place under the car. Then the front and rear you mount behind the bumpers. You should probably run the wire for the front one through the engine compartment and through the firewall. And MAYBE drill a hole for the rear one. Make sure you tape or split loom all wires on the outside of the vehicle. Then you hook them up to a switch and make sure they're fused properly. Its not easy, and its hard to say how to do it without seeing the car. If you are a stickler for sound quality, driving around with the underglow system on will interfere with your stereo.
Old 03-04-2004, 11:13 PM
wut is the firewall, and i donno how to run through the engine but um..... i also have no idea how to get into the car but um pictures would help
Old 03-06-2004, 12:47 AM
SIKCRX SIKCRX is offline
you dont even know what a firewall is. you definitly dont need to be "modding" a car, this is why no one likes ricers.
Old 03-09-2004, 12:04 AM
maat333 maat333 is offline
I would leave it to someone with more experience, because even if you drilled holes in the right place, it is dangerous to just run wires through sharp holes.
The insulation will eventually get cut through, and then you could fry your electrical system or even start a fire.
Even worse, you could drill into the gastank or something.
You need more experience that you seem to have.
Not only could you have modifications come loose and be broken, but you could get yourself and the car burned up in a gasoline fire.
Old 03-27-2004, 05:51 PM
nose-gobblin's Avatar
nose-gobblin nose-gobblin is offline
Send a message via AIM to nose-gobblin
no offence, but if your afraid of messing up i would recommend a friend or your mechanic to help u
