Old 03-03-2004, 07:47 PM
soyee7's Avatar
soyee7 soyee7 is offline
Banned
Resistor mod?
i was wondering if you can put a resistor in for the second o2 sensor on my 98 gst because i have no cat.
Old 03-03-2004, 07:56 PM
ashah000's Avatar
ashah000 ashah000 is offline
Send a message via AIM to ashah000
I am going to say yes right now, I think the resistor would be different.
For Sale 98 Eclipse GS, 5 spd
Old 03-03-2004, 08:19 PM
BoostedSpyder's Avatar
BoostedSpyder BoostedSpyder is offline
Send a message via MSN to BoostedSpyder Send a message via Yahoo to BoostedSpyder
Re: Resistor mod?
why? are you getting a CEL? i only ask cuz i have had my cat off since the second day i owned the car with no problems.
Old 03-03-2004, 08:29 PM
ashah000's Avatar
Re: Re: Resistor mod?
That is odd. Shouldn't you get one for the rear o2 sensor. Do you have a test pipe or gutted cat.
Old 03-03-2004, 09:24 PM
Re: Re: Re: Resistor mod?
my first exhaust was 2 1/2 custom piping from the DP back. i got it on the second day i had the car along with a k&n fipk. i have never had a CEL come on.
Old 03-03-2004, 09:26 PM
soyee7's Avatar
Banned
Re: Resistor mod?
yeah, my cel is on. it says "fuel trim malfunction"(Bank 1), so i think it may have something to do with the o2 sensor not reading right. It may also be because i have a 255 fuel pump and no regulator, so im gonna get a regualtor in a little bit and bolt that shit on.
Old 03-03-2004, 09:30 PM
Re: Resistor mod?
i have a 255 with no regulator too and i still don't have a CEL. you should post a thread regarding the reading.
Old 03-04-2004, 01:11 PM
soyee7's Avatar
Banned
Re: Resistor mod?
i have, and nobody can even seem to tell me what could be a possibility.
Old 03-04-2004, 02:04 PM
ashah000's Avatar
Re: Resistor mod?
Well the fuel trim malfunction is not from the second o2. I really dont know what that CEL means so i dont know, but it is not from the second o2, and the resistor only works for the second o2
Old 03-04-2004, 10:30 PM
kjewer1 kjewer1 is offline
AF - Advisor
Re: Resistor mod?
Yes. If it was the rear sensor the code would read catalyst system efficiency below threashold bank 1. The fuel trim code is typically the trims maxed out in one direction or the other. Could be from a massive vac leak, bad front o2 sensor, etc.
Kevin Jewer
RWD Talon - 7.92 at 180
Mightymax - 10.7 at 125
Old 03-08-2004, 02:59 AM
soyee7's Avatar
Banned
Re: Resistor mod?
do you think it could be from my maf. I removed the 2 side and the one lower honeycombs out of it but i left the one that is by the sensor on. A guy named Gabor who is the one of the DSM kings of the midwest said that that is my problem. what do you guys think?
Old 03-08-2004, 09:50 PM
AF - Advisor
Re: Resistor mod?
Yes, that will cause it. The ECU has 12.5% range ont he LTFTs, and 16% on the STFTs. So 28 total. The hacked MAS can alter air metering by over 30% at idle, putting the ECU out of its adjustment range thereby causing that code. Try unhacking hte MAS, its uselss anyway.
Kevin Jewer
Old 03-08-2004, 10:37 PM
95ClipseGS-T 95ClipseGS-T is offline
Send a message via AIM to 95ClipseGS-T Send a message via Yahoo to 95ClipseGS-T
Re: Resistor mod?
I have the same 0170 engine code on my car.My car is bone stock. The mechanice said check the o2 sensor so i'll find out tomorrow.Would this make the car not run right with a bad front o2 sensor.And wtf is unhacking the MAS
95 GST
5 Speed
Cone Open airfilter
Custom 3" Turbo Intake
UICP/LICP
1g BOV
JoeP MBC @ 16psi
2.5 Turbo back
16g
550cc injectors
S-AFCII
PocketLogger
95 GST
Old 03-09-2004, 11:46 AM
soyee7's Avatar
Banned
Re: Resistor mod?
how do you test an o2 sensor to see if it is bad.
