Old 03-03-2004, 07:27 PM
l2ice rocketz l2ice rocketz is offline
Send a message via AIM to l2ice rocketz
Break Squeals?
Well.. the brakes have started to squeal a bit. Not like the crazy squeals coming out of the really old oldmobiles in the ghetto, just like a mini-one. Anyways, judging from the squeals, are my brake pads like cracked in any way or something? I havent changed brake pads since last year august.
91' Civic LX 4G4D
May 1, 2004 9:20 PM
R.I.P.
Old 03-04-2004, 07:30 AM
lilol89crx lilol89crx is offline
Re: Break Squeals?
could be cracked, dusty, has debree embedded in the pad, i really cant pin point it for ya.....
Old 03-04-2004, 08:39 AM
sastanley's Avatar
sastanley sastanley is offline
AF Premium User
Send a message via AIM to sastanley Send a message via Yahoo to sastanley
Re: Break Squeals?
mine like to sqeak in the rain or right after rain. If your pads are worn, they should make a distinct scraping sound...but the squeal is a much higher sound and usually indicative of a dirty brake area...when you wash the car next time, try to blast out the brake dust as best you can. They do make grease that goes between the pads and the caliper that are supposed to stop the squeak. it is very cheap and sold at most auto parts stores...I usually spring for this when I change the pads, but it doesn't usually last their entire life...you may need to re-apply some now.
-Shawn
'91 Civic DX sedan
DOHC ZC, I,H,E, urethane bushings and mount inserts, rock chipped hood, some rust, stock steelies, nice comfy Integra seats, and the A/C works! What else could you want from an 18 year old car with 241,000 miles? Working on getting the Si tranny in now
Old 03-04-2004, 09:21 AM
i_a_n112784 i_a_n112784 is offline
Send a message via AIM to i_a_n112784
Sometimes the metalic content in the pad material will rub against the rotor, causing a squeal, and as the pad wears more, the the squeal may go away, or get worse. Brake dust will make noise too, so try to hose out that area back there, and if it still happens, its the metal in the pads.
Old 03-04-2004, 11:09 AM
4GZChatch's Avatar
4GZChatch 4GZChatch is offline
Send a message via AIM to 4GZChatch Send a message via MSN to 4GZChatch Send a message via Yahoo to 4GZChatch
Re: Break Squeals?
Just take it into any big-o tires or midas or whatever. they usually all have a free brake inspection service, and they'll diagnose it for you in the hopes that you'll tell them to do the work. Then just tell them you can't be without the car, and you'll call back to schedule or something... :
Remember: You can't spell Crap without APC!
Classic SE-R
GTi-R turbo setup
3" DP
U12 modified ECU
Hyperco GenII suspension
Progress sway
SAFC
etc. etc.
Old 03-04-2004, 09:00 PM
YZ125rider21's Avatar
YZ125rider21 YZ125rider21 is offline
Send a message via AIM to YZ125rider21 Send a message via Yahoo to YZ125rider21
Re: Break Squeals?
spray some wd-40 on it stop that in a second
Old 03-05-2004, 10:00 AM
88_SC_CRX_Si 88_SC_CRX_Si is offline
Did you use any of that stuff, you apply to the back of pads to hold down on noise. I have seen it called "Disc Quite" or something like that. It's super messy but it does work...
88' CRX Si - JRSC @ 6psi Z6 Mini-Me, JDM SiR Conversion
NOS #5122, JR Liquid InterCooling System
ZYDNE SECU, 450's
B&M FP Set, B&M Command Flo
AutoMeter - Phantom FP, A/F, N2O, Boost gauges & pods,
ARP HSKit, AEM Pads, 87' HF Drums, DYI CAI
