Speedometer
94 Bronco,dash with gauges and electronic speedo. Removed cluster to replace bulbs , battery was disconnected, speedo. is now stuck on 90 MPH. Any Ideas?
Re: Speedometer
remove it again and clean the connection where the harness plugs in and make sure it's plugged in all the way. sounds like some circuits got crossed.
Re: Speedometer
Thanks for the reply,but thats not the problem. I know this because I fixed it. It seems that in the Ford electronic speedo. in a 94 Bronco has nothing to hold it in the 0 mph. position. Apparantly, while putting in the bulbs, I moved the cluster enough to swing the speedo. needle over center and it rested on the 90 mph peg. Removed the cover,moved the needle to 0,speedo. works fine.
