Go Back   Automotive Forums Car Chat > Engineering/ Technical > Forced Induction
Forced Induction Discuss topics relating to turbochargers, superchargers, and nitrous oxide systems.
Old 03-03-2004, 07:31 PM
Shawn C Shawn C is offline
One more question about the BoV
Thanx for helping me earlier guys, but where is the hookup in a 1997 honda civic dx for the pipe off the top of the bov,, u said the throttle body but i was looking around and i dont see a clear place to put it.
Old 03-03-2004, 08:32 PM
duplox's Avatar
duplox duplox is offline
Send a message via AIM to duplox
Re: One more question about the BoV
Any vacuum fitting after the throttle body. there should be one somewhere, you will probably have to use a T fitting to split another existing hose...
Old 03-04-2004, 11:37 PM
quick95civic quick95civic is offline
if you are referring to the vaccum line from the bov the best place to connect it is at the stock fuel pressure regulator. Just get a "T" fitting from an auto parts store and put it in line between the manifold and the fuel pressure regualtor and off of the other fitting on the "T" run a vaccum line to the bov. Dont use the line on the back of the intake becuause it is not always under vaccum and dont use any on the throttle body because you want it to see vaccum when you shut the throttle
Old 03-05-2004, 03:11 AM
93hybridaccord 93hybridaccord is offline
What kind of turbo are you running and have you dynoed it yet?
93 accord - jdm h22a
2003 srt-4 - daily driver
