Go Back   Automotive Forums Car Chat > Volkswagen > Passat
Old 03-03-2004, 05:55 PM
Mainard Mainard is offline
Power windows not working
I've seen this issue brought up, but have never seen an answer: My '93 Passat GLX Wagon VR6 has intermittent power windows. Sometimes they work fine, other times some, or all don't work. They get stuck open, they get stuck closed, they even reverse function (you want them to go up, they go down). Most recently, none work at all in the fully closed position. When I actuate any of the window controls, I hear a clicking sound coming from the unit located under the left side rear seat cushion. Is this unit the culprit? Any idea what it's called? Is it something else?
Old 03-09-2004, 02:26 PM
Mikanik Mikanik is offline
that's what myn would do until I replaced the control module under the back seat. Expensive too!!! Cost around 300 dollars for a new one if I remember correctly.
nick
Old 03-09-2004, 03:25 PM
Re: Power windows not working
I've been told by the local VW dealer that it is the Window Regulator Control Module that's shot. He's giving me a price around $400. I'm off to the junkyard...
Old 03-09-2004, 06:00 PM
I've been told that the same Window Regulator Control Module was used in '90 - '94 Passats. It wasn't used in any other models. And no luck at the local junkyard; anybody got a lead on a good one?
Old 03-10-2004, 02:17 PM
There's tonz of places on the web that deal with used vw parts. Try searching and check around for prices. You could also try calling www.germanautoparts.com . maybe they can get it at a reasonable price. good luck.
Nick
Old 03-10-2004, 08:22 PM
boschmann boschmann is offline
Try car-part.com, look under computer box - not engine. It doesn't list it specifically but select one of the modules & it will give you a list of yards that have the vehicle and their 800 phone numbers.
Old 03-11-2004, 12:45 AM
karlos69 karlos69 is offline
Window controls - 1996 Passat
I am starting to see problems with window controls also.
Passenger side rear window no longer works (for the last year)
Now I just noticed that the power to the windows after ignition shut off that usually lasts a minute or two no longer works. (Note - I am having some ignition problems with secondary pressure so I have to start twice to get engine to start)
Any input appreciated
Karlos69
Old 03-11-2004, 12:58 PM
I located the window regulator control module at German Parts Warehaus (800-464-5284) for $75.00. Hope that does it...
