Go Back   Automotive Forums Car Chat > Ford > Focus | C Max
Old 03-03-2004, 03:59 PM
fallstonfireman fallstonfireman is offline
Focus Help on the Recall
I recently had the fuel pump recall done. Now the car runs worse than it did before they fixed the recall. I have taken it back to the dealership that did the recall and they keep saying nothing is wrong. It hesitates under acceleration and while driving at 55 mph. I have replace the wires and plugs. I am at my wits end on what to do next. I also was told that there was a hole in the EGR valve tube. Could that be causing the hesitation. SOME ONE PLEASE HELP.
Old 03-09-2004, 12:12 AM
maat333 maat333 is offline
Re: Focus Help on the Recall
The EGR should not be working at idle or at high speed.
When the EGR is on, the small pipe from the exhaust to the valve get very hot.
When it is not working, the pipe cools down.
So it is easy to check if the EGR valve is working.
First check if it is cool, then either rev the engine or such on a hose you attack directly to the diaphram port. You should be able to make it go on and off easily.
But actually EGR is very bad for a car. It causes corrosive deposits on the back of the valve stems.
Your car's performance and endurance would be greatly increased by pulling the hose off the EGR and plugging it.
Other things you can do to improve performance include advancing the timing a lfew degrees, and narrowing the spark plug gap.
But these can cause you to fail emissions tests.
Old 03-09-2004, 12:15 AM
One other thing that can cause hesitation are that the vacuum advance diaphram on the distributer could be perforated. You can suck on a hose to that in order to see if it holds vacuum or not.
