Go Back   Automotive Forums Car Chat > Oldsmobile > Aurora
Old 03-03-2004, 02:37 PM
Drama Drama is offline
Angry Oil Pressure Drop
HEEEEEEEEEELP! My oil pressure drops to 0 psi whenever there is some incline present (i.e. driving from the street to a parking lot). However, 0 psi is displayed for only few seconds when it happens. Comments?
Old 03-03-2004, 04:52 PM
Indy8's Avatar
Indy8 Indy8 is offline
Re: Oil Pressure Drop
A shop can hook-up a "real" oil pressure gauge and check it for you. Otherwise, if you know there's 7-8 quarts and it's not getting hot, it's probably the cars sensor. These are usually inexpensive to replace.
Quality isn't expensive, it's priceless.
Old 03-04-2004, 08:24 AM
Thanks for the prompt reply Indy8. You are right...the car is not getting hot, and there is enough oil in there (I am changing it every 3000-4000 miles). Can I replace this sensor myself? If so, where is it located? Thanks.
Old 03-04-2004, 08:39 AM
bustedratchet bustedratchet is offline
Right by the oil filter. It sort of looks like a small black tube. With wire connector on it.
Old 03-04-2004, 11:21 AM
Thanks bustedratchet. I'll look for it. Does the sensor have any special/fancy name instead of oil pressure sensor?
Old 03-04-2004, 01:30 PM
This is what I have found on the Internet....Is this the right part?
oil pressure SENDING UNIT, Aurora 96-99 $32.52
Electrical - Chassis electrical - Senders - oil pressure sending unit
Old 03-05-2004, 10:15 PM
Sounds right, This sensor is longer than most, you may need a special deep socket for it. Or you might be able to remove it with a 12 point box end wrench. It might also be easier to remove the oil filter first.
Old 03-09-2004, 08:18 AM
Thanks for the tip bustedratchet (tahnks to other fellas as well). Will order the part today.
Old 03-20-2004, 11:45 PM
GMkiller GMkiller is offline
Check your PCV valve and replace rubber grommet and elbows. $20.00 check. This should increase your pressure.
Old 08-27-2004, 09:12 AM
Just changed oil pressure sending unit. No help. There are some suggestions to fill additional 10 quarts of oil to the engine, then rev the engine from idle to 3500 rpm (open the throttle) in order to prime the pump (cycling the relief valve forces any debris from the relief valve). Thoughts?
Old 08-27-2004, 12:44 PM
99Intrigue 99Intrigue is offline
Re: Re: Oil Pressure Drop
Adding 10 extra quarts of oil to a full oil filled engine and running the engine is guaranteed to break something. After adding the extra oil the crank-shaft would be submerged in oil and the load it would put on the crank-shaft would ensure damaging some internal engine components. Try fitting a mechanical oil pressure gage, in addition to the electronic sending unit, to get an accurate reading. At the same time inspect the wires going from the sending unit and make sure the insulation in intact.
Old 08-29-2004, 08:26 PM
dsatt12 dsatt12 is offline
Actually 99intrigue, that was a GM service procedure that got posted a little while back here:
http://www.automotiveforums.com/vbul...d.php?t=255510
Old 09-01-2004, 08:43 AM
Low Oil pressure ...
Don't get me wrong, I love GM but they can screw up some-times.
They have a design problem with the oiling system in the engine and I'm supessed to trust that their Service Procedure will resolve the design problem?
Old 02-07-2005, 04:05 PM
I have done it, and it did not work? I also replaced oil pressure sensor. No results. Next suggestion?
Oil Pressure 130 Pounds Smith1000 Park Avenue 10 04-18-2011 08:39 PM
