Go Back   Automotive Forums Car Chat > Honda > Let's get Technical!
Let's get Technical! Discussion for hardcore in-depth motor heads!
Old 03-03-2004, 01:46 PM
BentHonda28's Avatar
BentHonda28 BentHonda28 is offline
Send a message via AIM to BentHonda28 Send a message via MSN to BentHonda28 Send a message via Yahoo to BentHonda28
Timing
Hey guys, I've got a '00 GSR that'll be running 8-9 pounds with a JRSC and Boost Kit. For those who've altered their timing, my question is what is the optimal timing setting for this setup? Fuel system is still stock, Nology HotWires are the only ignition upgrade so far. Any word is appreciated. Thanks.
'00 Integra GS-R- B18C1 w/: JRSC & boost kit(8-9psig), Comptech intake, ice box, exhaust, springs, Tenzo RS5's on Paradas(205/40-17), boost timing contr., CF hood, DC Header, strut braces, Type R LSD trans, B&M shift kit, dress up, M/T slicks with custom intake for the track, and more to list.
Old 03-04-2004, 11:42 PM
quick95civic quick95civic is offline
stock timing, if any adjustment maybe a very slightly retarded spark, but you should be alright with the stock timing, just listen and make sure you dont get any detonation. Get some colder than stock spark plugs and make sure the gap of the plug is low enough for the boost. At that level of boost you do need to upgrade the fuel system though. The easiest way is with a boost dependent fmu, and a high pressure inline fuel pump. I dont know about the teg but in my civic over 4.5 psi the stock fuel pressure regulator cant keep up with the fuel needed for boost.
Old 03-05-2004, 01:47 PM
Along with the pulley, included is a higher vol. fuel pump (one already came with the sc), boost timing controller, plugs, and thermostat. With the VAFC I'll be able to control the fuel output. The tech at JR said that around 8 deg was good for street, and around 10 to 12 for the strip. Stock is 16, so I'll just go from there. Thanks.
