Go Back   Automotive Forums Car Chat > Chrysler > General Discussion
Old 03-03-2004, 01:36 PM
Mikanik Mikanik is offline
94 lebaron Le
About 4 weeks ago my lebaron (3.0 V6) started too occasionally miss in the morning, after letting it warm up for a couple of minutes it would run normaly. Then about 2 weeks ago the timing belt snaped. I thought that it must be related to the timing belt, but it wasn't. After putting on a new timing belt and water pump it continued to miss in the mornings then would run fine after a couple of minutes. Now it's starting to get worse. It will miss even after it's warmed up. It has all new spark plugs, wires, cap and rotor. It seems that only one cylinder is missing. The computer has no codes stored in it. Has anyone ever experienced this before...maybe I have a bad fuel injector? I'll be trying to figure out which cylinder is missing, but until then any advice would be helpfull.
thanks
Nick
Old 05-06-2004, 06:49 PM
asspants asspants is offline
Re: 94 lebaron Le
take a look at your egr valve
make sure all your vaccum lines and hoses are good.
the mass airflow sensor could be bad too
you say you replaced the water pump, was it bad? do you think you blew a head gasket? check for compression on the cylnders
Old 06-12-2004, 06:57 AM
rcs426 rcs426 is offline
Re: 94 lebaron Le
ck one more thing injectors
Old 06-25-2004, 09:47 AM
NOS Buyer NOS Buyer is offline
Send a message via AIM to NOS Buyer
Re: 94 lebaron Le
i have a 94 lebaron gtc and nothing has happend to me like that yet. But try and check the vaccum lines. I have some people i know that would know the answer and ill check with them for ya.
