Go Back   Automotive Forums Car Chat > Toyota > Camry/Camry Hybrid/Vista
Old 03-03-2004, 01:42 PM
nyman nyman is offline
rattle
I have a rattle which I suspect comes from inside one or more of my struts when starting out cold --then disappears. Have double checked everything else. Has anyone heard of this?
Old 03-03-2004, 09:14 PM
fredbros72 fredbros72 is offline
Re: rattle
it can vary, usually you will get some noise when it is very cold, somewhat normal, common problem for strut noise is the upper strut mounts, either loosen up or just wear, try tightening 19mm nuts on top of strut, if does not tighten , usually need to replace,
it is possible might need struts, check for leaks
one other thing, are you sure strut noise, timing belt can be very noisy when cold, belt slaps cover when cold, gives rattling noise, goes away when warm, had belt been done and what is mileage, sounds like this could be your noise, check it out
Old 03-07-2004, 12:10 AM
rpmglide rpmglide is offline
Re: Re: rattle
hey, this explains that weird noise when on cold morning start ups. even though i had the timimg belt replaced at 100K. mechanic said it was no wonder it lasted as long as it did. also had water pump replaced, big heat difference.
Why does my driver side door still rattle over bumps? jberenyi Suburban 0 03-12-2009 09:52 AM
Rattle-Rattle and a cloud of smoke! dmoocher Cherokee 2 12-18-2004 09:33 AM
1994 SL-2 Cold Rattle/Warm no rattle slight hesitation acidburn_335 SC/SL/SW 6 09-27-2004 11:16 PM
A lil rattle rattle xviciousx Mustang Talk 4 09-05-2004 11:32 PM
