Go Back   Automotive Forums Car Chat > Ford > Falcon | Fairmont | FPV
Falcon | Fairmont | FPV Australian and American versions. Includes the XR6 and XR8 as well as FPV models like the Typhon.
Old 03-03-2004, 03:16 AM
thrasher_ryan thrasher_ryan is offline
Angry what diff ratio for better take off speed?
hey
I just bought a standard '87 XF Falcon and its totally gutless off the mark and im looking at getting a better diff but i have no idea what ratio to get or what will fit it.......
im also getting ....extractors
2.5 inch exhaust
lowering it
mags
thanks any help or ideas are good
Old 03-23-2004, 04:30 AM
somone reply my question
[hey ive had this question posted for like 2 weeks and noones replied me
cum on i need some help
cheers
Old 04-01-2004, 12:13 AM
PR_Jr PR_Jr is offline
I am not sure which ratio's are available for XF diffs, but you need to get "lower" gears.
ie. If it has 4.5:1 gears you want a higher number such as 5.2:1 for better take off.
However, better take off will result in lower top speed, but seeing as you only go as fast as 110 k/mh you will be fine
Old 02-18-2005, 04:17 AM
yevoXF yevoXF is offline
Re: what diff ratio for better take off speed?
I have an '85 Falcon S-Pack with extractors and a 2 1/2 inch exhaust and have replaced my previous 2.37:1(i think) diff with a 3.23:1 ratio LSD expecting better take-off performance. To a certain extent it helped reduce the amount of clutch riding but now has a problem with reaching red line to fast and due to a slow synchro 4 speed manual box i believe the ratio increase was too severe... It also revs a little too high for my likeing during highway driving(2900 at 100Km/h... fairly high considering it red lines at 4500).
Since the standard XF EFI cam provides max torque between 1000 and 2800 rpm I would stick to the standard manual transmission 2.77:1 diff ratio or maybe the 2.87:1 tow pack manual diff ratio.
In an automatic though the slow gearbox wont be an issue and the severe 3.23:1 ratio may be ok... personally i gonna go back to standard 2.77:1.
Here is a list of approx diff ratios available off the top of my head
2.37:1 Standard Automatic
2.77:1 Standard Manual
2.87:1 Standard Manual with tow pack
3.23:1
3.??:1 Only get if you have a 5 speed manual(so i have been told)
and upwards
Hope this has helped...
Old 04-23-2005, 09:06 AM
oldschool muscle oldschool muscle is offline
Like he said, if these cars make all they're torque down low then maybe you'd be alright with your stock gears. I still reckon you should go higher though, generally higher means faster quarter times.
how do take off the speed limiter on a 1.8 ecu gen1 4 life Engine, Transmission and Drivetrain 22 11-17-2004 08:47 AM
whats the best way to take off the tps smokeymicpot '88 - '91 Civic | CRX | Wagon | Shuttlee 3 06-20-2004 06:12 PM
Need more speed...trying to take off govenor...any suggestions?? jackel1028 Ranger | Courier 1 04-19-2004 01:30 PM
How to minimize torque steer and speed up take offs intelligence27 Off-Topic 0 11-19-2003 11:35 AM
