Old 03-03-2004, 03:56 AM
7th_skyline's Avatar
7th_skyline 7th_skyline is offline
Tamiya grey primer with Auto Acrylic sprays?
Will this be ok?
I have got enough tamiya grey primer left over to cover my stripped R31 shell. I also have the Holts Duplicolor paints to top coat it.
The question is, will they be ok to use together?
I'm using Holts clear plastic trim primer on my good R31 GTS-R body, but this is for the older one I have paintstripped , which really needs a primer to cover some of the blemishes...
so will it work?
Current projects:
-Tamiya KPGC10 Skyline into L28 powered "street racer"
-Aoshima "Puchiage Racing" Celica XX
-Aoshima "ChikiChiki Racing" C110 GT-X Skyline
-Widebody DR30 RS-X
-Tamiya F40
-Widebody HR31 GTS-R with Lamborghini OZ 345s
Old 03-03-2004, 07:48 AM
Verminator's Avatar
Verminator Verminator is offline
Send a message via AIM to Verminator
Thin coats may work ok, even though its acrylic it may have solvents in it. IMO you would be safer to buy some auto primer of the same make to be sure of compatability.
Old 03-03-2004, 08:38 AM
Bangai-o's Avatar
Bangai-o Bangai-o is offline
I painted the GT3 in my signature with halfords automotive paints over Tamiya greay primer and it was fine, look at the thread to see the results!
Ferrari 250 GTO Progress. Porsche 911 GT3 Complete.
Old 03-03-2004, 09:29 PM
SCUDERIA-FERRARI's Avatar
SCUDERIA-FERRARI SCUDERIA-FERRARI is offline
Send a message via MSN to SCUDERIA-FERRARI
Re: Tamiya grey primer with Auto Acrylic sprays?
Is The Duplicolor Laquer ?
IF ITS LAQUER OR ENAMEL THEN YOU WONT HAVE A PROBLEM BUT IF IT IS ENAMEL YOU NEED TO CLEAR COAT IT W/ ENAMEL ! THE MAIN RULE OF THUMB IS TO HAVE LAQUER UNDER ENAMEL ALWAYS !
Old 03-04-2004, 12:36 AM
Its Holts Duplicolor, I think it is acrylic lacquer? it says on the back "This Acrylic Lacquer...." . Then again, looking at my clear Holts plastic trim Primer, it says "This Acrylic Lacquer..." and even "use plastic trim primer on plastic..."
Fairly sure its acrylic.
Current projects:
-Widebody DR30 RS-X
-Tamiya F40
Flat base clear gloss coat? White primer Grey Primer? AllAlone.Gz Car Modeling 4 12-25-2006 07:42 AM
spraying X/XF Tamiya Axrylics - primer ? Bigsasquatch Car Modeling 3 08-16-2004 01:02 PM
Can I use neutral grey primer with tamiya yellow? Shalin Car Modeling 4 08-06-2004 06:11 PM
Whats the difference between Tamiya Grey Primer & Modelmaster Grey Primer? chubbs36chambers Car Modeling 31 02-14-2004 09:56 AM
white primer over grey primer v12horse Car Modeling 8 08-22-2003 09:54 PM
