Old 03-03-2004, 01:03 AM
BubbaGump24 BubbaGump24 is offline
Question Engine Swapping
I have a 76 F150 with a BB 390(original engine) thats blown and looking to replace it with a 351w from my 66(not the original engine) and was wondering what I would have to do to complete this swap. I know that I will have to change the flywheel because of the balancing issues. what I am unsure of the most are the frame mounts and driveshaft. Any help on this project would be greatly appreciated.
Old 03-03-2004, 01:08 AM
Re: Engine Swapping
Thanks for your input
Old 03-03-2004, 11:12 PM
surgicaltech's Avatar
surgicaltech surgicaltech is offline
Re: Engine Swapping
I might be wrong, but I think if you're using the same transmission driveshaft length should be ok. As for the motor mounts, obviously you're going to have to use mounts for the windsor. You should to try to find a 351/400m, it's a better engine, or even a 351 cleveland.. I personally don't like the windsors, had nothing but trouble with them...Hope this help a little....Mike..
dakota engine swap jpuckett13 Dakota 0 08-23-2010 07:21 PM
1995 olds achieva engine swap help. handymann3 Achieva 2 01-21-2010 09:26 PM
engine swap Cadillakin'98 S-10 1 10-22-2009 09:33 AM
engine swapping E. Frank Performance 6 08-07-2009 06:37 PM
97 Jimmy engine swap gsnats Problem Diagnosis 5 03-06-2009 09:40 PM
