Old 03-02-2004, 11:45 PM
kenny8869 kenny8869 is offline
Send a message via MSN to kenny8869 Send a message via Yahoo to kenny8869
Question 94 chevy brakelights
got a 94 chevy k1500. cargo lamp brakelight will work but not actual brakelights changed brakelight switch on the brake pedal and still no brakes is there a brake relay or something??? the fuse and bulbs are fine and the wireing harness to the lights seem ok????? anyone got any ideas?
Old 03-03-2004, 09:19 PM
brooster brooster is offline
Re: 94 chevy brakelights
Check your 4 ways and turn signals in the rear. The brake circuit feeds through the turn signal/flasher switch to the rear, but not the high mounted brake lamp. I've encountered some that I have fixed by merely turning the 4 ways on and off several times.
Have you checked the wires/sockets with a test lamp while the brake pedal is depressed? Check the wiring connector where it plugs into the bulb holder. On the left side it will be the yellow wire; on the right side it will be the green wire.
If you have power into the bulb socket holder when the brake pedal is depressed, try different bulbs. Bulb appearance can be deceptive.
88 chevy k1500 PLEASE HELP!!!!!!!!!! ironhand33 Silverado 16 05-03-2013 05:41 PM
2001 Chevy Cavalier Coolant System Problem getwilde Cavalier Problem Diagnosis 0 09-18-2009 06:43 PM
1995 chevy z71 instrument cluster problem BIGER_IN_TEXAS_Z71 Silverado 0 09-03-2009 04:22 PM
M62 supercharger on a chevy v8 350???????? duct996 Forced Induction 1 06-11-2009 11:17 PM
Chevy 350 cuts out! roknjock2 Chevrolet Classics 3 04-17-2009 07:13 AM
