Old 03-02-2004, 10:12 PM
gen2tegls's Avatar
gen2tegls gen2tegls is offline
Send a message via MSN to gen2tegls
where to ground my amp
ive tried 3 sopts to ground my amp and its still not working anybody know where a good spot to ground my amp is?????????
.\/.ENIGMA.\/.
Old 03-03-2004, 12:01 AM
gen2tegls's Avatar
Re: where to ground my amp
i have a 96 and ive tries on the seatbelt bolt under the seat ive tried behind the headlight there is a bolt ive tried drilling a whole into the frame and i use a wire brush and sand paper to take off all paint and dirt but still notihn is working....... i heard something about u seat railshow about that one of those bolts
.\/.ENIGMA.\/.
Old 03-03-2004, 12:34 AM
urweak urweak is offline
Banned
Send a message via AIM to urweak
i just relocted my battery to my trunk, and what i did was drilled a hold in the floor of the trunk down, right ontop of where the exhuast is. when down there with the ground and took off the bolt holding the bumber on put the ground wire on that blothed the bolt on agian works fine. also i cleaned it up a little with a file.
Old 03-03-2004, 09:44 AM
achievasc92 achievasc92 is offline
I grounded mine to one of the bolts that hold the trunk carpet in.
Old 03-07-2004, 12:44 PM
ligardo420 ligardo420 is offline
Send a message via AIM to ligardo420
You should try to take the amp out and connect the ground to the engine block. That will tell u if its a problem with ur amp. or not getting a good ground.
Old 03-08-2004, 05:15 PM
Frozenhonolulu Frozenhonolulu is offline
If the amp works when attatched directly to the battery you need to just add another ground for for the battery right to the firewall, or anywhere in the engine compartment. That's a pretty standard thing to do when adding an amp.
Old 03-08-2004, 08:15 PM
Ironman_375's Avatar
Ironman_375 Ironman_375 is offline
Send a message via MSN to Ironman_375
Alot of times i've seen it like this: say you've got 2 amps... ground wire from batt. post, g.w. from both amps come together, join them together and ground them the same place
amp 1---------|
batt-----------|-----------ground
amp 2---------|
In Memory of Brandon "Freebird"
You've all seen the "Priceless" credit card commercials, right??? How's this one:
Funeral Costs to your parents: $7k
New Truck for your parents: $23k
Payments to the family you've torn apart: $136k
Killing yourself, a 26 year-old woman, and her 4 year old Daughter from Street Racing: Not worth it...
Funny? Didn't think so... Save racing for the track
Rest in Peace, Brandon: Fly on, Freebird!
Old 05-23-2004, 06:22 AM
racerguy4u racerguy4u is offline
thats what i did, i have 2 amps runnin and i drilled a hole in the bottom of the rear deck and grounded them both there and they work great, it could be your ground wire isnt heavy enough.... i have 2 8 gauge goin into a 4 gauge to ground.
Old 05-23-2004, 12:02 PM
Allanon1313 Allanon1313 is offline
I just pulled back the carpet in the trunk and attached it to my antenna, like where it bolts on, just gotta remove the paint so you get metal to metal. works fine for me.
