Go Back   Automotive Forums Car Chat > Engineering/ Technical > Tires and Wheels
Old 03-02-2004, 08:34 PM
behvah78's Avatar
behvah78 behvah78 is offline
Smaller tires and acceleration
Any idea of how much time I can gain by changing my 17" tires to 15". The car has 200 HP and curb weight of 3400, Speed limiter at 180 km/h so I don't care about top-speed.
"Never drive faster than your Guardian Angel can fly."
[img]
http://us.f2.yahoofs.com/users/41b4f...__sr_/f414.jpg [/img]
Old 03-03-2004, 10:34 AM
Grant@Tirerack's Avatar
Grant@Tirerack Grant@Tirerack is offline
The main advantage of going with a smaller tire/wheel is a reduction in unsprung weight (depending on the wheel/tire). If you can reduce the total package weight of the tire/wheel on each corner you can expect a little improvement in speed off the line. If you can reduce your tire O.D. and maintain the load rating it will give you a slight advantage by changing your gear ratio on the back end of everything.
Grant
Your personal contact at The Tire Rack
1-877-522-8473 ext# 313
fax# 574-236-7707
email: [email protected]
