Go Back   Automotive Forums Car Chat > Porsche > 924/944/968
Old 03-02-2004, 08:24 PM
bianchis bianchis is offline
Interior gas smell
Hey guys, new to the forum here and have a question that I hope someone may be able to answer. I have a 944 N/A with 56k original miles and seem to have a strong odor of gas in the interior. Is there some air filter or charcoal canister that needs to be changed intermittently on these cars? Or is there any thing that can be done about this smell? Thanks guys
Andrew
Old 03-03-2004, 12:20 AM
matt944pca matt944pca is offline
Does it smell like exhaust gas as well? If so, look into your rear hatch seal. Otherwise, the charcoal canister is probably located in the drivers side fender near the firewall. Check out the lines first.
Old 03-03-2004, 02:35 AM
YeTi's Avatar
YeTi YeTi is offline
Send a message via AIM to YeTi
Re: Interior gas smell
i had the same problem... however, no exhaust smell.
turned out to be my fuel pump was leaking gas through the positive electrical terminal.
i quickly fixed that by getting a new fuel pump.
YeTi
Old 03-03-2004, 04:32 PM
Hey thanks for the replies guys. It doesn't really smell like exhaust so I will def check the charcoal and fuel pump/lines. Thanks for the help. I'll keep you guys informed on what I find.
Andrew
Old 03-05-2004, 03:12 AM
87Porsche951's Avatar
87Porsche951 87Porsche951 is offline
There is a cabin filter that alot of peopel dont change. It may be very old and need replacing. Replace that and see if the smell clears up.
Old 01-01-2005, 02:07 PM
mkellycole mkellycole is offline
Send a message via ICQ to mkellycole Send a message via Yahoo to mkellycole
Where is the cabin filter? I have replaced the rear hatch lower seal, checked the exterior charcoal filter for broken hoses and still get a bad exhaust smell while driving up to freeway speeds. I also have a bad gas smell right after filling it up. I just got it smog checked and the numbers are very low so I can't see it being a catalytic conv. problem. Any ideas?
Old 01-19-2006, 08:52 PM
I still have an exhaust/gas smell.I occurrs mainly when I open a window. I have replaced the rear window seal, charcoal filter and checked the fuel lines. The gas tank has been pressure tested and nothing obvious is showing a problem. More input needed.
Old 01-27-2006, 07:09 PM
RPM IM M RPM IM M is offline
hey guess what , we may be the only 2 people, because my 944 has the exact same issue. smells like raw fumes not exhaust and only a window open, and / or going around corners
Old 01-27-2006, 08:05 PM
So what have you done to track down the problem? I cannot find an exhaust leak, pressure in the tank is good. A guy at the dealer talked about some o-rings that could be bad. I will meet with him and get more details. Does you car run perfect? Mine runs perfect so I have difficulty changing perfectly good parts to troubleshoot the problem. The smell is difficult to say if it goes away after a few minutes because it is so heavy. I know that when I parked it in the garage the other day, the smell consumed the garage for a few hours. It makes me sense there is an oil leak burning on a header without any smoke. Maybe fuel leaking and burning off? Do you have any sources to fix the problem or out here on a limb like me?
Old 02-05-2006, 09:42 PM
backyard_engineer backyard_engineer is offline
just a thought, but maybe your gas cap is bad...its such a simple idea, we might forget about it. They are really cheap, so you might want to just get one and try it out. Who knows...
Old 06-13-2006, 03:07 AM
bill4brickwork bill4brickwork is offline
got the same problem 86 turbo noticed a very faint exhaust smell coming up from headers
Old 07-10-2006, 10:01 PM
Bob.white Bob.white is offline
had same problem. fuel rail leaks at mount bracket. very hard to find because it evaporates so quickly
Old 10-02-2006, 12:50 PM
FabricGATOR FabricGATOR is offline
Send a message via AIM to FabricGATOR
Originally Posted by 944_944Rad
PS I read somewhere that there is a two gallon reserve in the fuel tank. That mystery I have yet to figure out.
It is my understanding that you have two gallons to find a station after the orange warning light illuminates on the fuel guage.
I am not sure if that is in addition to the 26 some odd gallon tank or the last two gallons of it.
I noticed the other day, after a fill up, a fuel smell in the cabin. It also seemed that I did not get a full burn out of my tank, but I have an intermittant odometer also.
I will advise on my findings when I get around to working on it.... probably in a month or so (I'm Bad) that is unless it quits today then I'll report this afternoon.........
Hey! I'm not considered an enthusiast anymore........
2010 Toyota FJ Cruiser Trail Team Edition
2000 Mitsu Montero Sport (Trade In)
1987 944 N/A
1976 Buick Century (SCRAPED)
1979 Yamaha XS1100
I have a parking problem everywhere I go...
2004 Pontiac Gran Prix . . I don't care.
1993 Mustang LX . . . . . I don't care..
1996 Honda Civic CX. . . . . I don't care, well, maybe a just little...
I can't afford to love her anymore!
Old 10-23-2006, 09:29 PM
73Rx2 73Rx2 is offline
Send a message via AIM to 73Rx2
I had that same problem. I got another fuel rail, then it started leaking a month or so later. So I used some soapy water and my dads air-compressor to find the leaks and I used a flux-coated brazing rod and oxy-ace welded the cracks.
So far, that leaks been good to me *knock on wood* but I had to keep switching and fixing both fuel rails a few times. I think I solved it by testing them at a higher pressure. They must be shaking a lot to break there.
Old 11-15-2006, 08:33 PM
1998grandvoyager 1998grandvoyager is offline
I had the same thing on my 1987 944. Fresh raw gas smell when filled up all the way. Something to do with the overflow tube located in the gas cap area being disconnected. Which then drips gas into your left wheel well under your rear carpeting. This only happened when I filled her up to the brim with gas, which I didn't do anymore.
Andrew
Paul
1998 Plymouth Grand Voyager
3.3L
