Old 03-02-2004, 08:02 PM
senaclinton's Avatar
senaclinton senaclinton is offline
Antenna conversion...
I want to switch out my still antenna with an automatic/power antenna, and want it to only 'go up' when the radio is on (and down when it's off)...I'm 50/50 radio/disk listner. Is that possible? Any suggestions? Tips? Links? How To's? I did a search w/google and AF but nothing that helped...
Thanks for your time!
You're stupid, until proven otherwise...
Old 03-02-2004, 09:06 PM
PaulD PaulD is offline
Audio Guy
Send a message via AIM to PaulD Send a message via Yahoo to PaulD
ummm ... that's EXACTLY what the little wire labeled auto antenna does
Old 03-03-2004, 07:48 AM
Huh? So all I need to do is just switch it up...nothing hard?? I don't beleive yoooouuuu.... So beyond, that just some power wires and ground it out, huh?
Old 03-03-2004, 10:23 PM
Audio Guy
yep, that's it ........ you run that auto-antenna wire to the antenna and the the coax cable from the antenna to the radio - that's it (and you might have to ground the antenna. That power wire should run the antenna up and down with the radio
