Go Back   Automotive Forums Car Chat > Toyota > Camry/Camry Hybrid/Vista
Old 03-02-2004, 07:09 PM
Mike Gerber Mike Gerber is offline
AF -Advisor
dogbone engine mount question
The rubber portion of my dogbone engine mount, the one that attaches the engine to the passenger side front fender area, is slightly cocked to the passenger front side of the car. Incidently, Toyota calls this part an "engine moving control rod". The car is a 98 XLE 4 cylinder automatic with 68,000 miles. Is this normal on generation 4's?
Also, does anybody know the amount of deflection the engine will normally move if you brake torque it to about 1500 to 2000 RMP in drive? I have Toyota's technical service manual but can not find a specification for this.
Thanks.
Mike
Old 03-02-2004, 09:29 PM
fredbros72 fredbros72 is offline
Re: dogbone engine mount question
usually the dogbone shifts because the front lower engine mounts is worn out, the engine is lifting to high and putting too much strain on the dogbone, need to replace both if this is the problem, also, check the air intake tube, it can crack or tear under this condition
FS: **$30 Shipped** 1995 Eclipse Turbo Automatic Transmission Motor Mount thakid22 Classifieds 0 12-17-2010 06:32 AM
