Go Back   Automotive Forums Car Chat > Toyota > Camry/Camry Hybrid/Vista
Old 03-02-2004, 04:04 PM
nmikmik nmikmik is offline
motor mounts and struts on 95 Camry
I am back with more problems…
1. How do I replace the motor mounts?
Assuming, one at the time and supporting under the engine, so it does not drop down and do me more work that I was asking for. If support, where? Any suggestions?
2. Is there any way I can replace my own struts? The cheapest place I found ($440 over the phone…) was the shop that “tried” flushing my power steering and said that one quart is all they use!
Do I have to replace the upper strut mounts with the struts, if not how do I determine if they are good or not?
Thanks for all your suggestions,
Old 03-02-2004, 08:39 PM
fredbros72 fredbros72 is offline
Re: motor mounts and struts on 95 Camry
hey, motor mounts, support the motor with a jack,
1 bolt, 17mm on top, 3 lower 14 mm bolts on bottom, two on top one underneath, sneak mount out and sneak new one in , not too bad , jack it under the oil pan, use a piece of wood so not too damage pan,
struts, too save money , you can take struts out yourself, better off , taking struts too shop and have swap over, most of money is labor too remove, can do it yourself, but can be tricky,
front or rear struts,
usually do not have to replace upper mounts, sometimes bearings go in mounts , but most of the time ok, usually if leaking , want to replace boots, bumpers, and lower cushions, most rubber accessories, taking out the struts is pretty self explanatory, three small nuts on top, not the center one, two large nuts and bolts through hub,
Old 03-11-2004, 07:25 PM
Unhappy still at it
Well, I finally got to replace the front mount that was not too bad, forgot to replace the top mounting bolt… but the rear mount would not budge. May be/most likely, I am just doing it wrong. From the top, I could not get to it with the universal joint and a swivel extension. From the bottom I just couldn’t get the bolt loose with the wrench. Any tricks to do that?
Thanks for your help,
nmikmik
Old 03-12-2004, 04:13 AM
gator2764 gator2764 is offline
Re: still at it
nmikmik
Are you sure that the back mount is bad. Usually the Two front mounts go out. The bottom one and the top one(usually called the dogbone mount) located on the passenger side. On the strut issue are you sure they are bad? Are your tires chopped? My 95 has 169K on it and the struts are still good. Goodyear tried to sell me a set and after I questioned them about how good the tires were wearing they backed off the issue very fast, of course this was the same place that told me I needed to change the timing belt on my 92 P.U. after 218K miles. I told them if they could find the timing belt I would give them the truck. Damn thing has a timing chain!! That shut them up as well.
Old 03-12-2004, 11:59 AM
Red face not sure
No I am not 100% sure if I need that rear mount. The problem is that even after replacing both front and dog-bone mounts, it vibrates, actually shakes, at 55 – 65 mpr like crazy!
As soon as I let go of the gas, shaking stops, hence assuming it’s not the tire balance, bent axels, warped rotors (it would of pulsate the break pedal during breaking) or CV joints.
Any ideas?
Thanks,
nmikmik
Old 03-14-2004, 05:11 PM
rear mount is done
Just did the rear mount (the pain one) yesterday, still same vibration now it's in the shop, for alignment and balance (just called me the balancing machine is broke, so the balance is not going to be done today) if these two things won't fix it, then I really don't know what to do. Will let you know how it goes.
Thanks,
nmikmik
Old 03-17-2004, 05:33 PM
back at it
I finally got my car back from the shop that balanced my tires and did the alignment. Vibration is still there, same as before at ~ 50mph to ~75, then it all blend in… Mechanic sez “you probably lost one of the weights on the halfshaft or your tranny is bad". Took it to the transm .shop, they say, one of my rear breaks dragging(i did the breaks last week), but shafts and trany is fine?! I think before spending any money on other parts I’ll change tires, one of the weights after the balancing looked very big, may be it also out of round and nobody checks for that during the balancing of course… Tires are a year old but I think prev. owner had them replaced one at the time & had problems with them.
Any suggestions are greatly appreciated,
nmikmik
Old 03-18-2004, 12:19 AM
Mike Gerber Mike Gerber is offline
AF -Advisor
nmikmik,
Do you have a friend or relative with another Camry with the same tire and wheel size. If so, try swapping out the wheels and tires temporarily with that other car, one at a time, and then take it for a ride after each tire is swapped out to see if the vibration goes away. Conversely, if the problem goes away after swapping out a particular tire and wheel, then take the other car for a ride with your car's tire and wheel on it and see if that car now has the vibration. You may only need to replace 1 or 2 tires to solve the problem. (It is best to have tires of equal tread wear on the same axles.) I have seen problems like this develop if tires have not been rotated for a long time, and then they are finally rotated. This is especially true on front wheel drive cars. The tires on the rear have a tendency to bounce, since most of the weight is on the front tires. This bouncing may cause noticible cupping of the tires over time. Then when the rear tires are finally rotated to the front, the cupping causes a pronounced vibration that wasn't apparent when they were on the rear.
Good luck with solving the problem.
Mike
Old 03-18-2004, 02:53 PM
Thumbs up hope it's tires
Hey, thanks a lot Mike!
I was just thinking about swapping my Mazda MPV tires with the Camry and see how it goes, but never had the time to look at the size lol.
I will let you know how it goes as soon as I am out of the rat race…
Old 03-23-2004, 07:44 PM
nhuffb nhuffb is offline
Re: Re: motor mounts and struts on 95 Camry
What kind of tool to use to get off the bolts? any special tools? The space is so small that I can't get them off with the regular socket wrench.
Any idea?
Thanks a lot!
Old 03-27-2004, 01:39 PM
bolts
Are you sure you’re looking at the right bolts? I’ve taken mine out just with the deep socket and a short extension. You do have to take at least a portion of the front skirt off though. Oh yea, and jack up the car a little so you can get under it comfortably & don’t forget the jack stand, never leave it just on the jack!.
nmimik
Old 03-27-2004, 07:38 PM
camrytuner camrytuner is offline
Send a message via AIM to camrytuner Send a message via MSN to camrytuner Send a message via Yahoo to camrytuner
two things could be causing the vibration: frame damage or a bext axle.
Old 04-25-2004, 11:44 AM
perfsmrf perfsmrf is offline
Another thing could be a bent wheel. If you have steel wheels, one could be bent and cause the vibration. It happened to me.
Old 07-20-2004, 08:14 PM
Talking finally gone
Finally my problem is resolved after a few month and $500.00 … I just couldn’t keep it to myself. After replacing both axles, one of which had a bad CV joint and the other one bent & replacing both front struts the vibration is GONE! I a m pretty sure it was the bent axle causing the vibration but I guess I will never find out, nor do I want to.
Thanks again for all of your suggestions and help!
Old 08-12-2004, 11:35 AM
peter1 peter1 is offline
Re: still at it
nmikmik
I've a 92 camry 4 auto with vibration during acceleration.
Replaced dog bone and front motor mount...cut vib. in half.
Replaced tire (needed then anyway) cut vib. in half again.
But it still has vib. would like to replace rear motor mount.
How, my manual didn't cover it.
I can loosen the motor mount nuts but when I jack the eng. I don't get enough space to remove the old mount?
What am I missing?
Thanks
Peter1
FS: **$30 Shipped** 1995 Eclipse Turbo Automatic Transmission Motor Mount thakid22 Classifieds 0 12-17-2010 05:32 AM
