Old 03-02-2004, 01:07 PM
jbicb3 jbicb3 is offline
89 GP SE overheat or not
I have an 89 Pontiac grand prix w/150k miles. The temp guage started showing it was overheating, so I replaced the thermostat. Then the radiator began leaking, so replaced it, and was told by repair shop the water pump was bad. Replaced it, and the thermostat again. Radiator loses about a cup of water per week, sitting. No water in oil, or oil in water. When I run the engine, after about 10 minutes, the temp guage shows high temp (200) then drops back down, and up again. I can open the radiator cap at that time, and put my finger in the water. It's not hot. When driving it, the temp soars, then drops at random. The Low Coolant light also come on. When I check the coolant level, it is about an inch below the filler cap.
Overheats/ not the themostat wduden M Bodies 5 01-22-2011 03:38 PM
98 Sport Auto Transmission Overheats gromittoo 1st Gen 95-99 1 08-06-2010 06:16 AM
01 Blazer Overheats & Becomes Noisy Smilie1914 Blazer 2 07-11-2010 09:29 AM
94 318 overheats in traffic (aux fan not working) dt29332 3 Series 3 07-20-2005 06:17 PM
98 Cav overheats only when not using heat/ac venus Cavalier 10 09-19-2003 12:16 PM
