Old 03-02-2004, 11:51 AM
Holyterror's Avatar
Holyterror Holyterror is offline
Engine math: I6 + I6 = V12?
I know that various people have created V motors simply by merging two inline motors. Two I4s bolted together make a flat-plane V8, and two I6s make a V12. If I remember correctly, the TVR Speed 12's powerplant is basically two Speed 6 engines. Sounds like simple math, but here's my question: how do you go about designing a double engine like that? How much of the design can actually remain unchanged? It is really advantageous to do this rather than starting from scratch?
BTW, what would you guys think about combining two RB26DETTs into a 5.2 liter V12? Personally, I like the idea of a perfectly balanced twin-turbo (quad is just crazy) monster that puts around 2000 hp to the wheels. You would need a clutch from hell, though...
"There are no substitutions for revolutions."
Member of AF's Slide Squad (Member #05)
Old 03-02-2004, 06:20 PM
twokie twokie is offline
probably need a driveshaft out of a bus, too.
Old 03-02-2004, 09:59 PM
MagicRat's Avatar
MagicRat MagicRat is offline
Nothing scares me anymore
There have been many examples of this kind of engineering in the past. The advantage is that the cylinder head, valve gear, pistons, rings, bearings would remain the same. A new crankcase must be made, where they share the same crankshaft.
While it would be a new design, the advantage is in manufacturing, If its based on combining two inline engines to make a V, then all the same in line machine tools can be used. As it costs many millions to design and set up all the manufacturing tooling, the savings are considerable.
Old 03-02-2004, 10:11 PM
Evil Result Evil Result is offline
Send a message via AIM to Evil Result
yea i'v seen a Twin V8 in parallel where one engine would operate in reverse so the crankshaft gears would mesh together and that would be output to a transmission. Very awesome appearence with 16 headers pointing everywhere
I'v had this idea for a 12 cylinder engine not a V-12 or a L12, 2 L6 side by side with the flywheels that transfer power to a central fly to send power to the transmission, something you could also do is chance the ratios on the fly wheel for torque or top speed. so mabey top speed for the transmission and tortue for the acessories (ALT, AC, power steering, what ever).
Some benifits. shorter crankshafts, smaller diameter flywheels, mabey half engine operation if electric clutches where use on the flywheels.
I disregard my perceived image in the persuit of knowledge.
Old 03-09-2004, 10:24 PM
crash8168's Avatar
crash8168 crash8168 is offline
A 750il is precisely that, two six cylinder engines connected to get a 12 cyl engine. It has two of everything, including two engine controllers, imagine the expense of replacing both at the same time.
Old 03-09-2004, 10:54 PM
I think the 750 was 2 V-6 engines connect in series through a unified crankshaft, what i was thinking of is a parallel design unified through a fly wheel connection.
Also how difficult would it be to get 1200 HP from 366ci 12 cylinder engine, on say pump gas?
Old 03-10-2004, 12:15 PM
Cobra01TT's Avatar
Cobra01TT Cobra01TT is offline
Re: Engine math: I6 + I6 = V12?
A double inline 6 configuraton sounds much harder than two V6's. Just Turbo it and you can do any HP you want.
2001 Ford Mustang Cobra - Straight piped and loud as hell
2002 Yamaha R6 - Micron exhaust
1987 Chevy Corvette Convertable A.K.A. - The Pimpmobile
97 lumina engine acting erratically. aptivaa12 Lumina 5 04-22-2009 09:42 PM
For Sale Looking for engines or trannys?? StephanieO Parts for Sale 0 04-17-2009 09:24 AM
Will an engine from a 99 LX fit a 96? in_the_peg Crown Victoria 1 03-14-2009 09:06 AM
92 S600 Engine Needed - V12 bigg94 S-Class 2 04-09-2007 09:56 AM
