Old 03-02-2004, 10:54 AM
slimmcb slimmcb is offline
Send a message via Yahoo to slimmcb
any ideas
driver side window in my 93 sl decides that it will only roll up so far (less than half way)
could it be the motor? cause it will roll down and back up to the same point.
If it is the motor, something i could replace myself and how hard would it be
Old 03-02-2004, 11:06 AM
Teazrsnow Teazrsnow is offline
Send a message via AIM to Teazrsnow Send a message via Yahoo to Teazrsnow
Re: any ideas
sounds like something is in the way or its getting stuck spray som silicone on the sides
Tyler Laabs
2nd Place Drag racing Fwd 3s National Gathering 03[
Old 03-02-2004, 11:22 AM
Re: any ideas
Ill try that but what could be making it get stuck insid eth door there isnt alot that could have fallen in there right
Old 03-02-2004, 12:02 PM
Re: any ideas
no not really unless u have a nest of rats in there but no
Tyler Laabs
Old 03-02-2004, 12:14 PM
Re: any ideas
ok i just went and checked and the window will not roll up at all now, i can hear the motor running when i roll it down but whne i try to roll it up it rolls up very little i cant even get it up by pulling at the same time
Igovert500's Avatar
blue + red light magnet
Ok, I had a similar problem on my Honda, mind you I have never taken my 3000gt doors apart to look if they are even remotely the same.
But, on my honda, when I took the door apart, there were 2 metal beams in the shape of an 'X' that lifted the track that the glass was on. The two metal strips were bolted together in the middle and they would raise the window and then lower it. If lowered they would fold up almost flat over each other. So anyways, one of these metal strips bent from excessive use (13 years). And when it bent, this metal X could only extend to a certain angle, (so the window would only go 3/4 of the way up) then it would be blocking itself and would get stuck. So to solve this, I took the interior off the door, took out the screws holding in the metal x, had a friend hold the glass pane. and took out the metal X. I then beat the hell out of it with a hammer until it straightened, and put it all back together(making sure the window was back on the track). This solved the problem for a few weeks. Then it happened again. I have garaged my honda since, so I havn't fixed it permenantly, however, I imagine you could be creative and come up with a way to reinforce the metal so that it wont bend again. Hope this helps, Geoff
Old 03-02-2004, 12:20 PM
Re: any ideas
its definitely something that is stopping it then
Tyler Laabs
Old 03-02-2004, 12:26 PM
Re: any ideas
thanks alot i really appreciate it, i just looked for a motor and a regulator on the 3si just i know that they are super expensive to have replaced well for a window that is
Old 03-02-2004, 12:39 PM
Igovert500's Avatar
Re: any ideas
Hopefully it isn't the motor, it seems to me that if you are hearing the motor and if it was raising it halfway before then the motor is still working..That sounds really similar to the problem I had. It would work fine halfway up and then just stop. So check out that metal thing that lifts the track and window, because that is free to hammer, and it has to be cheap to replace(if necessary). And it only took me about 10 minutes to get to it.
Old 03-02-2004, 12:43 PM
Re: Re: any ideas
Wonder why they didnt make a manual backup on those alot of cars have that. Thansk for the info i really hope that it isnt the motor. i jsut haste to spend between 250-300 that isnt going to increase speed
