Go Back   Automotive Forums Car Chat > Isuzu > Rodeo | Passport | MU
Old 03-02-2004, 10:51 AM
mitch311 mitch311 is offline
What LDS additive did you guys use with Gear oil (GL5) for the diffy?
Hi,
I read the manual and it said to add some LSD (Limited Slip Differential) Oil/Additivie to the Gear oil when replacing the differential fluids.
What kinds did you guys used,....or is it even necessary for the additive?
Old 03-02-2004, 10:56 AM
rodeo02 rodeo02 is offline
The LSD additive (for the rodeo rear diff) is a tube of friction modifier liquid, that allows slippage of the clutch packs in the rear diff of rodeo's or troops equiped with LSD. The rear diff will chatter like crazy around turns if you dont use it. I highly recommend using OEM LSD additive from a zu dealer or www.stcharlesauto.com
G/luck
Joel
Old 03-02-2004, 12:16 PM
Re: What LDS additive did you guys use with Gear oil (GL5) for the diffy?
G/luck
Joel
Thanks.
How would you know whether or not your car is equipped LSD? I have a 2001 Honda Passport EX.
Old 03-02-2004, 12:17 PM
95.5 Rodeo's Avatar
95.5 Rodeo 95.5 Rodeo is offline
I bought it at the dealer; $6.91 plus tax. You must use it if your Rodeo has option code: G80 (LSD).
Option code reference:
http://www.itog.com/xr-001.shtml
Dale
Old 03-02-2004, 02:21 PM
kegard kegard is offline
St. Charles is definately the way to go! My local "stealer" wanted almost $17.00 for the additive! In fact the parts guy didn't even realize an additive needed to be added. I asked what they did when they performed their differential service, and he didn't know!
I think that I'll stick to my Haynes manual and you guys for as much of my maintenance as possible
Oil Pressure 130 Pounds Smith1000 Park Avenue 10 04-18-2011 08:39 PM
