Old 03-02-2004, 09:31 AM
12gauge 12gauge is offline
Thumbs down Poor Fuel Economy After Header Install
93 K1500 5.7L 4X4
I HAVE INSTALLED HEDMAN HEADERS WITH COLLECTOR BACK DUAL EXHAUST. MY MPG WENT FROM BAD (12-15) TO TERRIBLE (7-8) WITH THE TAILGATE OFF. I BELIEVE I SHOULD HAVE HAD AN INCREASE NOT A DRAMATIC DECREASE. IT RUNS BETTER BUT EXHAUST SMELLS VERY RICH.
I WELDED IN A NEW O2 SENSOR AND RUN ONLY THRUSH MUFFLERS. I CHECKED THE TIMING AND SET IT TO 1 DEGREE ADVANCE.
CAN THE FUEL MIXTURE BE ADJUSTED THROUGH THE COMPUTER?
-DEALERSHIP WONT EVEN HOOK UP TO MY TRUCK BECAUSE NO CAT
WHERE COULD I FIND SOMETHING CAPABLE OF ADJUSTING MIXTURE SHORT OF REPLACING ENTIRE INTAKE SYSTEM?
IS THERE ANYTHING I'M NOT THINKING OF?
ANY SUGGESTIONS ARE GREATLY APPRECIATED.
THANKS
-12 ga
Old 03-02-2004, 10:17 AM
USN Jim USN Jim is offline
Re: Poor Fuel Economy After Header Install
12gauge, You need to reprogram your computer for your mods. then you will see and feel a differents. Summit,Jegs, and performance products has what you need. Performance products has alot for Silverados.
Hope this Helps, Jim
Old 03-02-2004, 05:26 PM
juma33 juma33 is offline
programming won't hurt but this sounds more like you have a leak at the exhaust manifold gasket or somewhere else downstream. the leak is feeding in oxygen which is read as lean condition and the computer is adding more fuel and trying to run richer. usually, with headers you end up running lean for a few hours till the computer adjusts and this is within the self-adjustment of the computer.
or maybe some vacuum line has been left off the intake??
its sounds like much to drastic a change to be something that won't require repair.
juma
Old 03-04-2004, 03:54 AM
THANKS GUYS,
UNFORTUNATELY I HAVE A 93 AND "THEY" DONT SELL TO MUCH AS FAR AS REPROGRAMMING, ESPECIALLY IN A REASONABLE PRICE RANGE.
JET MAKES A STAGE 2 MOD THAT IS SUPPOSED TO HELP TRUCKS THAT HAVE HEADERS AND DUALS AS I TAKES INTO ACCOUNT THE LOSS OF BACK PRESSURE BUT IT DOESNT SAY ANYTHING ABOUT MILAGE GAINS.
I DONT BELIEVE THAT THE MANIFOLD GASKET LEAKS HOWEVER I WILL RETORQUE THE BOLTS AT THE MANIFOLD AND THE COLLECTORS.
I HOPE THIS HELPS. AS I TRY THIS, ANY OTHER HELP IS SURELY NEEDED.
THANKS AGAIN
-12 ga
Old 03-04-2004, 04:33 AM
MrEleven MrEleven is offline
Send a message via AIM to MrEleven
I am not a mechanic by trade...but backyarders like myself say to unhook the battery, then reattach and see what happens. also i would run it hard for a couple of hours and see if you make it to a gas station. sometimes things are simple.
The man who paid for my truck
