Old 03-02-2004, 06:49 AM
gumwils gumwils is offline
Hot Hot Wheel on 97 Mustang
My 97 Mustang's rear passenger side wheel gets super hot if traveled around 25 miles or more (from one end of the island of Guam to the other, one-way). Checked brakes, calipers ok, brakes turn, (just changed brake pads to see if that was problem, no help). Checked e-brake, it functions ok. Run out of things to check. By and by, car came with ABS. ABS no longer functioning, $1400 to fix system, not interested. Any suggestions on what could be wrong. Thanks
Old 03-02-2004, 07:30 AM
Chrisv6Stang Chrisv6Stang is offline
Send a message via AIM to Chrisv6Stang
Well, when u drive do you hear any grinding or any smoke coming from the wheel when u stop?
Old 03-02-2004, 05:13 PM
Re: Hot Hot Wheel on 97 Mustang
Brakes work fine. No grinding or smoke. GUMWILS
Old 03-02-2004, 07:06 PM
stang_racer20's Avatar
stang_racer20 stang_racer20 is offline
Send a message via Yahoo to stang_racer20
You said the ABS is not working, maybe it has to do with that, ya never know. Otherwise maybe you should bleed the rear brakes. Perhaps something is causing the piston to hold up?
92 Mustang GT, 347 Stroker(Forged Steel Crank/Rods-Balanced, Forged Alum Dished Pistons), B50 Block, Track Heat Intake, Twisted Wedge Heads w/ Stage 3 port/polish, 80mm C&L MAF, FMS 30# Inj., BBK AFPR, Trick Flow Stage 2 Cam, Trick Flow 1.6R Rockers, BBK EL-CC Headers, MAC O.R. H-Pipe, Flowmaster Cat-Back, Accufab 75mm TB, MAC CAI, BBK Pulleys, Griffin Alum Radiator, Mark 8 Fan, MSD Pro-Billet Distributor; AOD, Dynamic 3300 L-U Converter, B&M Trans Cooler; 3:73 gears.
Old 03-02-2004, 11:17 PM
Mendari Mendari is offline
Make sure your wheels are not torqued at a higher rating than the factory specs. If they're torqued too high, you may have worn out the wheel bearings. This may be causing the heat problem.
Old 03-02-2004, 11:58 PM
StangNut86 StangNut86 is offline
Send a message via AIM to StangNut86 Send a message via Yahoo to StangNut86
Re: Re: Hot Hot Wheel on 97 Mustang
you may have just hit the proverbial nail on the head.
definitely check those bearings. support the car on the rear axle and try to wiggle the tire around in a couple directions (horizontal and vertical work fine). even if you dont' feel teh wheel clicking, i would still pull the axle and look at the bearing itself. this involves opening the rear differential, so it would be a helluva great time to change your gearing =D. also, check your rear diff fluid, just in case. oh yeah, and if somebody dropped the ball and didnt' grease the wheel bearing sufficiently, that would definitely cause your problem.
-Andy
'89 Mustang 5.0 - How fast? i'll know this weekend.
'86 Mustang LX - Shortblock is built, now for the rest of it.
"Put the subject before the verb, hmm? Fail this class, you will."
-Yoda teaches english class.
