Go Back   Automotive Forums Car Chat > Pontiac > Sunfire > General Discussions
Old 03-02-2004, 04:18 AM
how2lose101 how2lose101 is offline
High Beams not working????
Hi all,
I have recently come across a new problem with my 2000 sunfire. My highbeams no longer work . When I switch from lowbeam to high I get nothing but darkness. Any ideas what might be causing this and is it easy to fix?
Thanks
Old 03-02-2004, 05:05 AM
amac209 amac209 is offline
Send a message via MSN to amac209
Re: High Beams not working????
could be a number of things. start by checking the fuses and bulbs. it's not likely both bulbs would die at the same time but check them anyways. could be broken wire somewhere i believe the dark green wire to the headlights is high beam. could be bad switch, circuit breaker.
Old 03-04-2004, 06:00 PM
muzikmannn muzikmannn is offline
I've had this problem and it was corroded wiring under the car in the left wheel well area
Old 03-05-2004, 09:37 PM
hopeless4life hopeless4life is offline
Send a message via MSN to hopeless4life
Its the recall that should be but never will be. Its probably that wire that muzikmann mentioned. If you have a sunfire you probably will hit that problem
Old 03-15-2004, 05:17 AM
How much did it cost to fix? And thank you both for the response
Old 03-30-2004, 09:29 PM
sunchic96 sunchic96 is offline
hey im new on here and I saw your post, I have a 96 sunfire and my Highbeams doesnt work either. I've been running on lowbeams and drl's. I've checked everything and thought it might be my headlight switch so Im goin to try that, I'll let you know what happens...if you havent got yours fixed.
Old 03-31-2004, 12:03 AM
Cool, let me know if that works for you....still haven't fixed mine yet. Gonna wait for something else to break first before taking it in lol
Old 03-31-2004, 01:26 PM
me2003 me2003 is offline
light problem
I have the same problem with my 96 sunfire, the hi beams dont work, just my low beams work. If you find out whats wrong post it here.
I wondering if mines the module because if i leave the hi beams on and turn the car on and lights on they flicker quick and then off.
Old 03-31-2004, 08:38 PM
I'll let you all know how it goes with the switch replacement. I should have it done in a week of so. Mine did the same thing before they went out I used to turn the car on then the lights, they would blink and go out. I dont know it's all f**ked up though. Anyway I'll make another post when I know more.
Old 04-04-2004, 02:25 PM
Hey all! Well installed the new switch and it didnt help the problem so we took back. If you do try changing the switch though you dont have to take the whole wheel off, just the top piece. We also got a new relay and tried it but nothing happened so it went back. The only thing we can think of now is the wiring. Be checking it soon. I'll let you all know what happens. If anyone else has any ideas let me know.
Old 04-04-2004, 07:40 PM
lights
Ive checked all my wire, and no shorts or nothing, i tryed the relay too. I am going to try and get the drm module and see if that works. I actually think that is what is wrong, if it works i will get back to you.
thanks
Old 04-17-2004, 12:00 PM
Boomsly Boomsly is offline
I have a 1998 2.2L sunfire that has the sme problem we havn't had highbeams for about a month now and the problem started when we took our car into a near-by Gm dealer to get a recall on a firestarting wiring harness replaced. Ever since then we've had no highbeams. when we pull the lever to turn on the high beams the highbeam light on the dash doesn't show up, does that mean it could be the switch or something else?
