Go Back   Automotive Forums Car Chat > Pontiac > Bonneville
Old 03-02-2004, 03:42 AM
kaspr kaspr is offline
replacing supercharger coupler?
I was wondering how I am able to tell if I need a new coupler? And furthermore, is it a difficult process to take off of nose of the supercharger? Is there anything else I should replace while I'm at it?
Old 03-08-2004, 07:23 PM
radeohedca radeohedca is offline
Useful info on S/C coupler
From what I understand, a worn coupler will make clunking noises and if you remove the belt, you will feel excessive backlash when rotating the S/C pulley back and forth.
I bookmarked the following info a little while ago (got it off a local Grand Prix SIG site) .
This link shows you how to take the S/C snout off to access and replace the coupler. Great detailed pictures and how-to info.
http://www3.sympatico.ca/aepa/blowerinstall.html
These guys carry new & improved replacement couplers at a decent price.
http://www.zzperformance.com/zzp/pro...sc_coupler.htm
(No commercial affiliation.)
Cheers, Hugh
Old 03-21-2004, 05:35 PM
BonneMeMn BonneMeMn is offline
Send a message via AIM to BonneMeMn Send a message via MSN to BonneMeMn
You'll need to pull the whole Supercharger off to do this work. It looks like you can pull it off the main housing, but you'll spend much more time doing this.
Good luck!
Old 12-04-2004, 10:42 PM
ebonyoutlawz ebonyoutlawz is offline
Re: replacing supercharger coupler?
Thanks dude.....Your info saved me a bundle. I replaced my coupler and it works fine.......Peace
Old 10-25-2005, 06:18 PM
jasonbrock21 jasonbrock21 is offline
Send a message via AIM to jasonbrock21 Send a message via Yahoo to jasonbrock21
cool - finally someone with pics - I just recently purchased a 92 bonneville that has that notorious rattling at idle and knew that it was just a simple repair -all my techs at my job (goodyear) said it needed a whole new supercharger. but it does look easier to remove the whole supercharger. so what kind of boost should be factory on these cars? Can it be changed without changing the pulley? Is it computer controlled or vacume controlled.
later
Old 11-04-2005, 02:45 PM
its840 its840 is offline
Send a message via Yahoo to its840
its vacuum controled and about 9# and the only way to up psi is with a smaller pulley. and the dealers will only change the supercharger they wont repair them cause gm claimed that the eaton m90 supercharger is not rebuildable.
