Old 01-04-2002, 07:30 AM
EliteImports's Avatar
EliteImports EliteImports is offline
Question 92-96 Civic Suspension, please HELP
i need some input here and i know the true PH(af) ppl are the right ppl to get it from:
"The first thing i want done is the suspension totally replaced. In the case of other civics i've seen that were fast they were incredibly rough rides which took away from speed do to all the bouncing and swaying. so i want mine ready for the mods i'm putting on. so this is how it is
I've decided to go with Neuspeed because they are a good company and have decent prices. My first choice was Eibach but they are extremely expensive so Neuspeed it is.
This is the list of stuff i'm looking at purchasing
1. Lowering Springs
2. Anti Sway Bar (rear)
3. Front upper strut bar
4. Upper and lower tie bars(rear)
the only thing i'm really not sure on here is will the upper and lower tie bars fit back there with the anti sway bar. do they both do the same thing or what? and if i can't have both and i get the tie bars do i need both of them and will they fit properly?
Last but not least i've decided that for the sake of being safe(i've had control bushing problems on my current POS) i'm going to swap out all the bushings with Prothane preformance bushings. that way i won't have to worry about em for a while.
Well leave me your thoughts and comments. I would like another opinion besides my own cause i want to get the most out of my car. "
Old 01-04-2002, 10:58 AM
ric's Avatar
ric ric is offline
Send a message via AIM to ric
anything you do to your suspension for performance is going to make it stiffer no matter what you try. one thing i didnt see listed in your item list was struts, i would seriously consider getting new struts if you are going to be doing all this. and also depending on your drop you may need a camber kit. usually a drop below about 1.4-1.5ish will start to need one. as for the sawy bar and tie bar thing, they should both fit on with each other with no problem since they dont have the same mounting location unless they are extremly bulky but then i would be worring more about the sway bar ripping out the sub framing if it was to bulky. as for a decent sway bar for a civic i would have to say the stock civic si rear bar is the best way to go, anything thicker like a suspension techniques and you might run into problems. tie bars are tie bars when it comes to the underside ones just try to get one that doesnt have to many adjustability points in it cause those are areas of stress exertion and you dont want concentrated stress points, thats what your trying to get away from. as for the upper strut bars i woudl say neuspeed's that arent adjustable, they are a royal pain in the ass to fit in sometimes but provide more rigidity because they are not adjustable.
as for the difference between strut tower bars and sway bars.
strut tower bars are bracing to reinforce frame rigidity
sway bars are used to transfer energy produced on one side of the suspension during conering to the other side of the suspension to equal dispersion out as best as possible.
Old 01-06-2002, 01:20 PM
hobbesboarder hobbesboarder is offline
Send a message via AIM to hobbesboarder
let us know how it turns out please u pics
Torque wins races, horsepower sells cars
furture plans: bumper,fenders, sideskirts, paint, cf hood, rims
...and god said let there be rice and doors of APC opened and the Ricers came in multitudes for L.E.D.s and Type R badges.
