Go Back   Automotive Forums Car Chat > Honda > Let's get Technical!
Let's get Technical! Discussion for hardcore in-depth motor heads!
Old 03-01-2004, 09:04 PM
EG_Civic's Avatar
EG_Civic EG_Civic is offline
Engine RPM drops when Headlights are turned on
When I turn my headlights on, the idle drops probably 250 - 350 rpm. Is this normal? its not alot, I was just wondering if maybe the alternator is going bad. Any tips?
EDIT: I dont have a tach in the cluster, so Im guessing on the RPM, its probably closer to 100 RPM. Anyway, its enough to hear but it wont stall or anything.
Old 03-01-2004, 09:14 PM
SilverY2KCivic's Avatar
SilverY2KCivic SilverY2KCivic is offline
Cali Guy
Send a message via ICQ to SilverY2KCivic Send a message via AIM to SilverY2KCivic Send a message via Yahoo to SilverY2KCivic
Maybe have it checked out, but esp. on older cars, it's pretty normal as the headlights can and DO put a slight load on the car's electrical system, which inturn powers the car from the electricity that has to flow to the spark plugs to ignite the fuel.
Silver '00 Civic EJ6 Coupe
PureHonda original member since Feb. 2000
D-series revolution For pics of my baby, click here!
All rights reserved... All BITERS served!
"The last time you had THIS much fun driving a car, it cost a quarter, and gyrated in front of the supermarket."
i have yet to see any well done imports around here. most are road toilets driven by some high school punk -Drift
hessemer69 on AIM
Old 03-01-2004, 10:22 PM
Tomsriv Tomsriv is offline
Re: Engine RPM drops when Headlights are turned on
100 rpm is normal. If it drops a lot it could be due to a weak battery (it acts as a voltage buffer) or a worn alternator.
Old 03-02-2004, 09:09 AM
EG_Civic's Avatar
Yeah, its closer to 100 rpm. If its normal, then I wont worry about it that much. Im gonna have to get a heavy duty battery/alternator anyway for my system.
Old 03-03-2004, 09:08 AM
88_SC_CRX_Si 88_SC_CRX_Si is offline
There is a slight lag before the Electronic Load Detector (ELD) sensor can signal the ECU. To increase the fuel injector pulse width, to compensate for the added load. It can take ut to 3 seconds in some cases....
88' CRX Si - JRSC @ 6psi Z6 Mini-Me, JDM SiR Conversion
NOS #5122, JR Liquid InterCooling System
ZYDNE SECU, 450's
B&M FP Set, B&M Command Flo
AutoMeter - Phantom FP, A/F, N2O, Boost gauges & pods,
ARP HSKit, AEM Pads, 87' HF Drums, DYI CAI
Old 03-04-2004, 10:25 AM
Might want to check the tension on the alt. belt, it could be slipping a tid-bit.
Just a thought...
ZYDNE SECU, 450's
Old 03-04-2004, 11:02 AM
Ricochet's Avatar
Ricochet Ricochet is offline
Banned
It's normal as long as driving isn't effected..
Old 03-04-2004, 05:01 PM
SRV BOY SRV BOY is offline
Thats normal, my rpm drops when I use the power windows and sunroof, and I just put in an
ac delco heavy duty battery.
