Go Back   Automotive Forums Car Chat > Ford > Ranger | Courier
Old 03-01-2004, 08:39 PM
RangerBill71 RangerBill71 is offline
Headlight and highbeam problem 97 Ranger XLT
Neither headlights nor highbeams are working. Checked the fuse, does not appear to be that, not the bulbs. I think it's the headlight switch that is malfunctioning. What is the cheapest easiest way to fix this or to determine if this is the problem? Thanks!
Old 04-24-2004, 05:14 PM
basilio basilio is offline
Unhappy Re: Headlight and highbeam problem 97 Ranger XLT
the cheap way or should Isay gehto is to run a hot wire from battery to the lights with a togle switch turn them on/off.But no brites.
Old 04-24-2004, 07:40 PM
Thanks but my wife is making me take it in to get fixed "right".
Old 10-25-2004, 10:27 AM
Epigod Epigod is offline
I had the same problem. You need a new "multipurpose switch" which is the high/low beam switch wiper control and turn signal. Sounds bad but it aint. $45 from ford dealer and a few torx screws on the steering column. 30 minute job max.
