Old 03-01-2004, 07:35 PM
FastTalon FastTalon is offline
1991 Talon Ecu
Is it common for talon's ECU to go out? My car doesnt start and my mechanic told me that its my ECU.. Did anybody have the same problem? thanx...
Old 03-02-2004, 05:05 AM
MrZ's Avatar
MrZ MrZ is offline
Re: 1991 Talon Ecu
FastTalon;
Yes, it is common for the ECU (or ECM) to fail on these year Talons. Some people are content to find one at a bone yard, but I personally don't recommend that route, as you don't know when and where the unit might fail on you.
There are a number of places where you can send your unit for replacement or repair. Do a google search (or any search engine will do) for eagle talon ecm, and you will find them. Most offer at least a 6 month warranty on their units. Typical cost is between $200-$250.
Mark
Old 03-02-2004, 04:32 PM
1stGenRocks's Avatar
1stGenRocks 1stGenRocks is offline
Send a message via AIM to 1stGenRocks
Re: 1991 Talon Ecu
look on ebay i got one for my 92 talon there for 80 bucks with a 1 month warr for 130 i could have got one with a 1 year warr theres a company that has like thousands of ecus for sale on ebay
btw i got on for my 93 eclipse from a junkyard and it worked fine just make sure to match up the part #s
-1stGenRocks-
95 Tsi AWD: 6 bolt, DSMLink, 880's, ACT 2600, lightweight flywheel, AGX's, Dropzone springs, poly motor mounts and suspension bushings, 3 inch turboback, gus modded 1g BOV, hardpipes, drilled & slotted rotors, 17's
plans: bastard 20g, water/meth injection NO FMIC
Old 03-02-2004, 04:49 PM
MrZ's Avatar
MrZ MrZ is offline
Re: 1991 Talon Ecu
1stGenRocks;
I didn't know you could get them through EBay. I would still advise against picking one up from a bone yard. They often times fail with no warning at all, and that's not something you want to have happen.
Just as an added note, when mine failed I sent it to an outfit in Texas, and they repaired the one from my car. They told me they replace components in the circuitry that are substandard and known to fail. Of course they didn't tell me what exactly they replace. I've read since then that it is the capacitors in the unit that eventually end up leaking. My point is, getting your unit repaired as I did is probably the most reliable option out there, because you have the assurance of knowing that the weak link in the unit has been eliminated.
Mark
