Go Back   Automotive Forums Car Chat > Honda > Integra
Old 03-01-2004, 07:15 PM
KounT KounT is offline
Send a message via AIM to KounT Send a message via MSN to KounT
where i can find vtec head
ok few questions..first, does anybody know where i can find a vtec head from a gsr or type r in the tampa area and for how much i could get it for? second, i have a 91 teg ls so would there be a certain year for the head i have to get and if so what year? and also is there anything else required like wiring or the ecu or somethin like that? any help is appreciated
Old 03-01-2004, 10:15 PM
95TegSE's Avatar
95TegSE 95TegSE is offline
Check junkyards, or ebay (be careful who you deal with). The b16a head is essentially the same as the type-r head, with the exception of the port/polish job and less agressive valvetrain. You might want to look into one of these if you want to spend less money. As for electronics, I believe the 91ls is obd-0, but I could be wrong. In this case you'll need an obd-0 vtec distributor, obd-0 fuel injectors, and an obd-0 vtec ecu.
From the foothills to the bay, it shall ring, as we sing,
It shall ring and float away; Hail, Stanford hail! Hail, Stanford hail!
Old 03-02-2004, 06:16 PM
Re: where i can find vtec head
ok well do you kno how much this would cost, both junkyard and ebay plus all the obd-0 stuff
Old 03-03-2004, 04:46 AM
95TegSE's Avatar
You can find a complete b16 head for around $400-500 then the ecu would run you about $200, the distributor for around $150 and RC engineering injectors will run you about $300, I dunno how much oem ones would be.
