Go Back   Automotive Forums Car Chat > Ford > General Discussion
Old 03-01-2004, 03:40 PM
caspersdad caspersdad is offline
86 ford tempo electtrical
the tempo i have is eating batteries they last about 3 days i have 2 that are on a circular pattern ,i keep exchanging them , between car an charger, the alternater is putting out 13.5 volts, the car runns gr8 with a charged battery but as the batterie weakens the idle increases and doesn't kick down,and the lights dim, turn signals fail to flash, an shortly there after the car dies .... any suggestions ? my wife uses the car to get to work and i worry about her gettin stranded
dave
Old 03-01-2004, 07:07 PM
cpujunky cpujunky is offline
Re: 86 ford tempo electtrical
there is a lengthy way to test your alternator to find out if the regulator is bad or if the circuit wire from alternator to ignition is bad.
Buy a haynes automotive repair book.Look in section 5-17 and 18.It will explain a quick way for you to test where your problem is.
I would tell you but its too much steps to test plus the book has pictures.
Also you can get much more help at www.tempotopaz.com
Go there and register.You can get alot of help there.
