LS1 in a 93 camaro
Hey guys, heres the deal, i have a 93 camaro with the standard v6, auto, the v6 is shot. i have found a place that will sell me a LS1/T56 combo with MAF, ECM, harness, clutch, hydaulics, pedals, shifter, belt acc. starter, fuel injection, exhaust manifolds, and bell housing. I know the mounts need to be changed, but what else needs to be taken into account here. rear end?, fuel lines/pump? speedo and other computer? cooling system? driveshaft? please help.
Re: LS1 in a 93 camaro
the driveshaft will probly be different, the computers are different, so youll have to loose the orignial. with those cars most options, such as the speedo are controled by the BCM, the ECM you are talking about is actually the PCM. so that shouldnt have an effect, the rear ends between the two are the same, only difference is some have a torsen, and some have a auburn in the posi units. open are the same. fuel lines may be different, im not sure exactly, but anyone who can do simple pipe bending can help ya on that. to build a adapter line for ya. the crossmember where the trans mount is could be different, so you will have to look at that. cooling system should be fine so long as you can hook it up to the LS1, probly have to either make, or find a set of hoses that happen to work. the fuel pump should be fine, ummm, thats all i can think of right now. but there will certainly be pages of gremlins that pop up, no doubt about that.
Chevrolet Camaro - I enjoy beating the hell out of people http://www.automotiveforums.com/vbulletin/showthread.php?t=68052 |
The driveshaft is the same because its the same transmission and rearend.
The PCM and torque converter will be different along with the motor mounts and accessory brackets.
93 Z28 383 LT1 http://members.shaw.ca/desiz28/Dyno.wmv ![]() http://members.fortunecity.com/gripenfelter |
On topic, you will have to get different mounts for the engine. I would recomment just buying yourself a nice new tubular k-member from BMR or another suspension company. They are lighter and stronger than stock. You also want to make sure you upgrade your fuel pump. I believe the LS1 injectors run at 28lb/hrs or something like that, and I'm not sure the v6 in tank pump will be able to handle it under WOT. You don't need to upgrade the rear, but you'll never be able to lauch if you have the open diff, you'll just spin forever... Get a torsen or auburn posi unit and call it good... Incidently, I will have one for sale here in about a week... I'm swapping in a built rear for my stocker, but the stock one is in great shape. I just got a steal of a deal on the built one, so it was cheaper to swap rears than do a gear change... Let me know if you are lookin at getting a posi rear... I'll part with it for a pretty low price...Everything else should just be replacing the v6 stuff with v8 stuff they give you... |
Re: Re: LS1 in a 93 camaro
[quote=hot_red_z28]
You don't need to upgrade the rear, but you'll never be able to lauch if you have the open diff, you'll just spin forever... Get a torsen or auburn posi unit and call it good... Incidently, I will have one for sale here in about a week... I'm swapping in a built rear for my stocker, but the stock one is in great shape. I just got a steal of a deal on the built one, so it was cheaper to swap rears than do a gear change... Let me know if you are lookin at getting a posi rear... I'll part with it for a pretty low price...QUOTE] I resent the never be able to launch comment
Grand National. Going fast with class. Voted FASTEST street car on AF. Here is the proof!!! 1987 Buick Grand National. Back in action!!!! 1999 Ford F-250 Tow rig from hell 598 Ft-lbs. ASE Certified in... Mobile AC On Highway medium duty diesel engines. Off highwayy medium duty diesel engines. On highway trucks. Working on the eletronics certification Member ofA.A.N.B.C- Afer against non boosted crews #2 |
If you have a 2 piece driveshaft it won't work but if you have a one piece it will.
Just think what you'd be able to do with a posi unit... I bet your times would drop by between .2 to .4 seconds...
the driveshafts on the v-6s were 2 3/4 of an inch shorter than the v8's. you have to change the engine cross member and the trans crossmember. also you need the fuel pump off of an LS1 car, and the transmission will only work if it was originally out of an LS1 car. also i would recommend that you upgrade your rear-end just cause 2.73s on an LS1 would be depressing. you would also obviously need the v8 exhaust and ive heard that you need to change the heater hoses, dont know if you care about that. it is definitely a huge job, bigger than the LT-1, i am actually surprised that no one had said to sell the car and buy a 98, thats usually what is recommended...
Thanks for all of the help guys, i will try to keep you all posted on how it goes, if it happens.
Tom |
