Go Back   Automotive Forums Car Chat > Chevrolet > Chevelle
Old 03-01-2004, 12:41 PM
xXx Loki xXx xXx Loki xXx is offline
What blowers are available for a 1966 Malibu 327ci?
I have looked online but I can't find any? Any links would be appreciated.
Old 03-01-2004, 02:42 PM
litlmustangmoody litlmustangmoody is offline
Re: What blowers are available for a 1966 Malibu 327ci?
their are a SEVERAL different blowers you can put on your motor. I have a 69' 327 and recently pulled off a weiand 6-71 blower. the issue is not really what blowers are available for yours it's more of how big you want to go and how much boost you would like to push. B&M - WEIAND - PROCHARGER - KENNY BELL - and NOVI all make great superchargers. if you are looking for a roots type blower and only wanting to push about 7-12lbs I would go with a weiand 6-71 or maybe even a 8-71 those in which I have had great experiences with and they look really good. you can go to Ebay and look around they usually run around 2,000-2,500 for the blower and intake adapter for your motor. just remember when you go to do this that you will probably have to have a really small distributor like a mallory unilite or something like that to clear the back of the blower case.
Old 03-21-2004, 11:59 PM
drvngstorm05's Avatar
drvngstorm05 drvngstorm05 is offline
i would recommend procharger ones, just get one that fits small block chevy's and u'll be fine
www.procharger.com
'92 RS lt1/t56, lt4 hot cam, 30lb injectors, 54mm throttle body, full exhaust, 4.11 posi, 4 coil ignition, alluminum driveshaft, adj rear suspension, low. springs, electric water pump, custom tune.
