Go Back   Automotive Forums Car Chat > Honda > Let's get Technical!
Let's get Technical! Discussion for hardcore in-depth motor heads!
View Poll Results: which motor is the best for a 90-93 integra?
ITR 0 0%
GSR 0 0%
CTR 1 16.67%
b16(non type r) 0 0%
ls/vtec 2 33.33%
gsr block/b16 head 2 33.33%
H22 1 16.67%
Voters: 6. You may not vote on this poll
Closed Thread Show Printable Version Show Printable Version | Subscription Subscribe to this Thread
Old 03-01-2004, 11:25 AM
formby formby is offline
Question b18c block/b16 head what next
i have a rebuilt 92 teg with auto tranny... i am thinking on building a gsr/b16 hybrid (poor mans type r) this with a gsr mt tranny...
now this is the deal i am putting ctr cams and pistons, 4-1 header, spoon IM, dont know which computer..was thinking of a p72 (ITR), lude injectors,msd with nology wires and ground wire kit. light weight flywheel
should i use b16, ls or gsr tranny? ls or gsr puel pump?i am trying to stay jdm...am i missing anything
what could i do to loose weight don't mind taking interior out...might put 4 racing seats
ALL SUGESTIONS WELCOME
Old 03-02-2004, 06:43 AM
Plastic_Fork's Avatar
Plastic_Fork Plastic_Fork is offline
Re: b18c block/b16 head or ls vtec
I have a B16A so can tell you first-hand the B16 transmission gearing is very short. For your particular application I would choose a transmission with taller gears such as the LS or GSR. I believe the LS gears are taller than the GSR. The GSR's gearing is designed more for faster acceleration from a dead stop, but the powerband should last longer with the LS gearing.
As for the fuel pump, if you're building a GSR block, then I would just use the GSR pump. I don't think there's really a difference between the GSR and LS pumps from the factory, although I could be wrong.
1995 Honda CRX del Sol VTEC
Manufactured: Suzuka, Japan
Production Sequence #1269
Team Del Sol member #1131
HondaVision: Team Sol Forum - Home of Team Del Sol
Old 08-13-2004, 02:01 AM
SiRspeed SiRspeed is offline
Re: Re: b18c block/b16 head or ls vtec
what other modifications do i need to make???? is it a direct bolt on??? i'm planning on putting a 99 b16 head on a 94 jdm b18c1 block....pls reply with info thanks....
here's my set-up
jun titanium valve springs and retainers
jdm ctr pistons
jdm ctr rods
skunk2 stage 2 cams
spoon cam gears
p&p b16 head with ported b16 manifold
mugen head gasket
68 mm ericks racing throttle body
exedy racing clutch & flywheel
hondata 3b system
how much power can i get with this set-up????
this is for a 99 civic si with a 94 jdm b18c1 gsr shortblock..............
Old 08-14-2004, 04:25 AM
jcrx jcrx is offline
Send a message via AIM to jcrx
Don't listen to this bullshit.
LS tranny sucks unless you are trying to get good, high, cruising speeds on the highway, the B16/GSR/ITR trannys are ALWAYS faster, and very capable of going much faster than the law will let and will get to speed faster. They are NOT too short. The logic of this is...vtecs make power where? Up high, so why in gods name would you want a tranny that got there slower, that is fucking retarded.
The two best trannies are the JDM ITR, or a GSR with a LSD. The ITR will be faster due o the shorter final drive, but the GSR is a great geared tranny, fast in the front and still has a nice top end.
Old 08-20-2004, 02:02 AM
95TegSE's Avatar
95TegSE 95TegSE is offline
And don't forget, the GSR tranny has dual synchros in 1st and 2nd, or was that 3rd too? and the ITR has dual synchros in every gear.
From the foothills to the bay, it shall ring, as we sing,
It shall ring and float away; Hail, Stanford hail! Hail, Stanford hail!
Old 08-20-2004, 05:33 PM
KrNxRaCer00's Avatar
KrNxRaCer00 KrNxRaCer00 is offline
Send a message via AIM to KrNxRaCer00 Send a message via Yahoo to KrNxRaCer00
5 mos old...
com'n now...
-closed
2003 Infiniti G35
99 Yamaha YZF-R6 (sold)
2000 Acura Integra Type R (sold)
1994 Acura Integra GSR (retired/sold)
Closed Thread
