Old 03-01-2004, 08:29 AM
Marr-TA Marr-TA is offline
Question Coolant temp
ok, My 94 bird (5.7L) stays at about 160 when cruising but when I'm sitting still the temp will go up to 220 or so before the fan/fans kick on and cool her down then it starts climbing again... It's a vicious cycle! It has been like that since I bought her a few months back. I have pulled the fans off and wired them to a 12 volt source and both work, I've replaced the coolant temp sensor, thermostat and I just replaced the water pump while changing out my opti. Is this normal? I am use to my cars always keeping a constant temp at a stop. Thanks everyone...
Old 03-01-2004, 07:21 PM
BadAzz240's Avatar
BadAzz240 BadAzz240 is offline
Send a message via Yahoo to BadAzz240
Re: Coolant temp
this is normal....cruising it will stay low but at idle it doesnt take long to get hot... i have a manual fan switch that I wired in myslef for bout 10 bucks and I flip that on and leave it on and it kools off pretty quick. U can kick the heater on high for a min, also and it will take some heat away... I would wire in a fan switch so when you are in traffic or whatever just flip it on...but the fan still operates normally also this is just wired inline with it so u can bypass the sensors if u want. Lemme know if u need help
Just for the Stroke of it...
Old 03-02-2004, 07:44 AM
Re: Coolant temp
Thanks BadAzz. I ordered a Jet fan switch in hopes that it will work to keep it at a more constant temp.
94 s-10 blazer 4.3 w temp guage! exalteduser Problem Diagnosis 8 08-26-2009 04:54 PM
p0128 coolant temp below thermostat regulating temp ? heffronjr Venture 5 01-12-2008 01:36 AM
High Coolant Temp and Low Coolant Warning Lights flashing scott3689 SC/SL/SW 2 10-25-2007 08:28 AM
1990 735IL coolant temp problem bweera 7 Series 4 07-29-2006 06:40 AM
735i coolant temp problem. viper2m 7 Series 3 06-28-2002 09:55 AM
