Old 03-01-2004, 06:47 AM
lacy lacy is offline
Unhappy 97 3.0 reverse shudder
Hi, my 97 with 3.0, 3 speed shifts fine except when starting to back up it shudders. any ideas? It has 144,000 , is it time to get rid of? Thanks
Old 03-12-2004, 01:16 AM
bzeilstr bzeilstr is offline
Sounds like a broken motor mount. Block the wheels and put on the E-brake. Open the hood and have someone watch as you place the running vehicle in Reverse. You should see the engine jump a little if the mount is broken. It's OK to push very slightly on the gas during this test but if your E-brake is shot, don't.
Bill
Old 03-13-2004, 12:17 AM
trannyman52 trannyman52 is offline
would guess ,,,direct clutch problem {in the transmission} any problems
with 3rd gear ???? this clutch is used in 3rd also. Not real cheap to fix,
but you take such a hit to sell broken!!!
Old 04-02-2004, 10:29 PM
mrrob mrrob is offline
How Bout?
I had a the reverse band plate break, I was getting a clunk when I put it in reverse, I am not saying it couldn't be a mount problem, but if they are ok, remove the pan and check the bank adjustment.
2000 3.0 trans shudder in reverse jimh Taurus | Taurus Wagon 1 10-20-2010 07:15 AM
91 mighty max 3.0 parting out Rip_Jeff Mighty Max 0 07-27-2010 06:04 PM
89 Voyager Valve Train 3.0L Nate1169 Caravan | Voyager 0 09-12-2009 01:11 AM
2000 3.0 24v hard to start wagon. Tglass Taurus | Taurus Wagon 4 07-07-2009 02:26 PM
How much is a 95 3.0L Voyager With 95k & Bad Tranny Worth? LightShifter Caravan | Voyager 2 05-30-2009 09:19 PM
